c pillar wall help in a 2000 mountaineer/ explorer xlt 6 ab xfl 1222s???
Is this possible with fitting in 2 mids and highs amps and eventually 2 dc5KS and 6-8 xs d3100s. Not for burpin ,daily driver demo beast. Any help or ideas let me know
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Anyone
I think you'll need to supply measurements. I'm currently doing a false floor in my 2004 aviator from c pillar back. My rough measurements are 44 wide, 38 long and 38 high I think. But I'm pretty sure the length could go a bit more before touching the 2nd row.
not 100% sure but if it's anything like a Tahoe it will work. Remove interior panels back there though to gain more room. group 31 batteries are 7" wide so you could fit 6 for sure but 8 might be pushing it. Just have row of batteries on bottom alllllll the way to the back, amps mounted above them. not sure what space those subs need or how big you can make the baffle, but make sure port is adequate
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
2.4-2.5 cuft per sub and tuned to 32-34 hz
And 15-16 sq in of port per cube.
Measurements of the useable space in your vehicle
Clarion cz702
Ssa evil mids and tweeters
ppi 900.4
2 zcon 18s
Taramps 10k
3 big dekas 1 xs
3 runs of 4/0 and big 3
300+ amp ohio generator
155.7 on dash at 36 (peak) 152 at 25
Will get back to you on that
Port will prolly have to bend since wall will have to be semi-shallow, I don't think you would fit many subs, but I am noob when it comes to enclosures. Definitely need the measurements. I was just guessing earlier.
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
here are the max dimensions
w 4ft trunk opening (max with of box)
w 41 7/8 hump to hump (between wheel wells)
w 52 7/8 widest lower point
w 63 3/8 window to window
L 40 3/4 Middle Max!
H 3 ft 1/4 tallest point Max!
H 33 3/4 Back tallest point
H 17 Bottom window line side windows
H 16 3/4 Bottom Window line Back
H 21 3/4 Headrest of Rear Back seat (would prefer lower but this is the max height for box want to see out the back window)
H 19 1/2 top of back seat no head rest
H 5 3/8 height of hump (wheel wells)
These our my measurements let me know of you need more
Need to fit 6-8 d3100s 2 dc5KS and 2 mids and highs amps and wiring fuse holders etc.
  • Who's Online   0 Members, 0 Anonymous, 10140 Guests (See full list)
