Wasteland_Audio Posted June 15, 2016 Report Posted June 15, 2016 So after one of my late night box designing escapades, i ended up with this. It takes 80 (yes, 80) sundown x6.5 subs, coming out to 0.186ft^3 per sub after displacement on the sealed sides (sundown recommends 0.15ft^3), and exactly double that on the ported side. I just used a 2 inch roundover pvc around the port exit. So i guess my main question is would this theoretically work? I know it's just for fun but i figured what the hell lol.
DLHgn Posted June 15, 2016 Report Posted June 15, 2016 I don't know if this would actually work but it sure is interesting! If it did, would be neat to hear what it sounds like and see what it would actually look like in person.
Wasteland_Audio Posted June 15, 2016 Author Report Posted June 15, 2016 Well i'll give you permission to use the design, just fork over $14000 for 80 6.5s lol. It would be pretty awesome to hear it actually play, and cone area actually more that 8 18s. Plus it will slide into the back of a suburban and still be behind the 2nd row.
kalilac619 Posted June 15, 2016 Report Posted June 15, 2016 It'll work....similar to the audiotistic build http://www.stevemeadedesigns.com/board/topic/118875-audiotistics-astro-64-tens-rockford-fosgate-build/#entry1671562 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
White Lightning Posted June 15, 2016 Report Posted June 15, 2016 If I was to buy 80 drivers ... I'd want to see them like space mountain. Just saying Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
DLHgn Posted June 15, 2016 Report Posted June 15, 2016 Well i'll give you permission to use the design, just fork over $14000 for 80 6.5s lol. It would be pretty awesome to hear it actually play, and cone area actually more that 8 18s. Plus it will slide into the back of a suburban and still be behind the 2nd row. If I had 14K just laying around begging to be spent then I would definitely consider your offer! Lots of cone area and doesn't totally give up the functionality of your car? Sounds good to me...aside from the ridiculous cost! I wonder what the low range output of these drivers would be. What are the ports tuned to?
Wasteland_Audio Posted June 15, 2016 Author Report Posted June 15, 2016 It'll work....similar to the audiotistic build http://www.stevemeadedesigns.com/board/topic/118875-audiotistics-astro-64-tens-rockford-fosgate-build/#entry1671562 So i just read that entire thread and i am extremely upset that i didn't think of this first lol. and a 156? i was expecting it to be in the 160s. Maybe it's just a really inefficient design?
mrd6 Posted June 15, 2016 Report Posted June 15, 2016 I imagine the sealed up mic on dash score would be low since you have two sound sources more or less fighting each other. I bet if you were to seal up the passenger side compartment the score would go up. It probably wouldn't demo as well though...who knows haha My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
DLHgn Posted June 15, 2016 Report Posted June 15, 2016 Just read that 30 page thread...wow. That van looks so awesome.
Triticum Agricolam Posted June 15, 2016 Report Posted June 15, 2016 That design certainly is interesting. Whether or not it will work probably depends on your definition of "work". I have no doubt that it will make noise, however the layout of the ported sections make it unlikely they will perform as Helmholtz resonators (like a regular ported box does). Most likely they are going to function like short transmission lines tuned to around 66 Hz. You are likely to get a peak in output at that frequency and below that the box is going to perform like a regular sealed box. While it may have more cone area than eight 18's, its not going to have more swept volume due to the relatively low Xmax (16mm) those subs have vs what most 18's have. At frequencies where output is limited by cone excursion the 18's are going to stomp all over that box. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
