Box Design SA's
Daddy_
Joex or anyone could I get a design for 2 10 SA's tuned to 34 hertz?
Car: 2012 Acura TL Elite
Head Unit: JL Audio Fix86
Front Stage : Alpine SPX-17PRO
Rear Stage : Alpine SPR-60C
Component Amp : JL Audio HD 600/4
Sub : 1 12" JL Audio W7
Sub Amp : JL Audio HD 1200
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 2 7/8", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
. Joe X is just a beast great box , u should charge for your great work u do I always see u helping here that's awesome.
Are these for the 10s or 12s?
It's for two SA-10s as you requested.
Dont the SA 10s need 1.25? Could you also mock up a single chamber design for 2 SA 12s single chamber tuned to 34. And theses designed take into account of woofer displacement also right?
Didn't notice you wanted 1.25 net per driver, now is changed so watch your power with that box size, and yes the displacements of both drivers are accounted for, it would be meaningless to provide a spec without considering displacements, the SA-12s box is already posted in the first page.
The sundown 1500d is good power for this box for the 10s u did
  • Who's Online   0 Members, 0 Anonymous, 779 Guests (See full list)
