DC Sound Lab
Hey iv had some systems before but nothing major just too simple 12s...I'm looking to hit some hard base now... I'm thinking of 2 level 5 15s Subs I was wondering would it be enough to run to 5K DC amps one for each sub what do you guys recommend wood 2 Xs batteries be enough in the trunk and one under the hood I wanna run them at full potential was still safe if anyone can help me out here I'd appreciate it and thank you in advance
With 2 m4 Lv5 15s either a pair of 3.5s or a single 7.5 would run them fine, just make sure you have the alt and battery power for it and your good to go. If you want to be able to really push the limits of the subs then get the 5.0s. the 5.0s will make over 5000 watts each, just make sure there set super clean , the level 5 is a 3500 watt rms subwoofer
DC AUDIO
Phone Number
1(855)SPL-DBZZ
Built by Competitors, for Competitors.
It was greatly appreciate it I'm going to check their site also another thing is I don't know if I should convert them to 1 ohm or just hook them both straight up to the amp positive to positive negative to negative I've been reading up on it but I'm still not a hundred percent sure I completely get it I don't no if I should get a 4 ohm or 2 ohm is there any difference in power
A good system starts with good electrical.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
For sure I've been reading up on that back in the say when I had a few systems I never ran 1/0awg and I never had extra batteries I never did The Big Three but I'm going to now I'm going to run an extra battery if not two extra batteries in the trunk and also a better amg under the hood
