Think my new alt is not up to par. Or am i just expecting to much form what i have.
i see no problem going on there what so ever..... if you want a BIT more help at idle add reserve. I have no clue why your worried. :unknw:
My problem is idle output, I don't like dropping into 11s with my new 300 amp alt when,my factory alt would hold voltage about the same at idle, I now see my problems and will do what I need to to be happy and fix them. Going to take out the batcap, put in a big agm, and so a few runs of good wire
Easy to see. Clamp the thing. But i would do the runs of OFC and such. But,.... Clamp the thing, and then, you know. Not guessing.
Your alternator is constantly giving your batteries a float charge whenever the vehicle is on, hence the higher voltage compared to when it is off.
When you are drawing more current from your alternator then it support you run in to voltage drop.
If your wire can not support the current draw it heats up adds resistance and also will cause voltage drop
When your voltage drop goes below of the resting voltage of your batteries you are running out of reserve.
A fence is only as strong as its weakest link, in your case Im sure it is the wire not allowing the current to go from point a to point b in 1 pass.
Once you get that weakest link fixed you may have another, you may not.
The only way to tell is upgrade the wire and see where your at.
What wire would yoh go with if it was you?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
anything that is silver tinned OFC.
And true to spec or oversized,
Don't buy cheap undersized wire.
Knu wire is nice
And so is the sundown wire, both are pretty close price wise too.
Knu wire is nice
I was thinking kun wire.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
O I put this setup on the meter not to bad for 1 18 in a small box.. Will Dr going to a show next Saturday, hope to do well,
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Mwspl style, sealed up.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   1 Member, 1 Anonymous, 473 Guests (See full list)
