Need help
GS300Cali93
80w per side
Per side meaning what?
That if i had two of then there would a total of 160 rms as a pair
Im just trying to make sure i match them with the right amp with other speakers and my tweeters im getting
$_57.JPG?set_id=880000500F
120 per 6.5
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
80w per channel means per side, so it is 80w on the left and 80w on the right.
Any amp up to 150w ch will do fine for those comps.
The more power the better your sound will be at higher volumes as the amp will not get to the point of distortion.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Ok i think i get what you mean
make sure you set your gains with the right tools if you throw double the power at them. Or even the rated RMS or you will damage the speakers. Research and get help with your system.
  • 1 month later...
You said "without the tweeter", does that mean your going to have an active setup? Meaning ur not going to use those "passive crossovers" that comes with that component set? So youre asking for the rms of a single 6.5 in that set?
  • Who's Online   0 Members, 0 Anonymous, 1053 Guests (See full list)
