How does power effect my enclosure
Usually when you over power a sub (depending on how much) you build ur box smaller to help with cone control. If its only a few hundred watts over rated RMS i wouldnt worry about it. If its more than say 500 watts over rated RMS you may wanna build slightly smaller box. The trade off maybe slightly louder (may or maybe not auidable to your ears) when over powering VS longevity of your sub.
+1 to what Bayuk said.
In addition, enclosure size effects the frequency response of the sub. Larger enclosures will have a larger peak in output around the tuning frequency than smaller enclosures will.
If you are trying to get as loud as possible, the trick is to build the enclosure as large as you can and still have it fit the space you have available and still keep cone excursion at a reasonable level for the amount of power you are going to be running. Its a bit of a balancing act.
Builds:
My sub is rated at 2000 rms and my amp makes 5000 rms at 14v but im holding steady 13 so im assuming im making 3500 to 4000. I plan on running another 15 but i want to see how much i can squeeze out of this single woofer.
The more power you have, the bigger the port needs to be to keep port velocities reasonable. Bigger ports eat up box volume so its another trade off.
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 2967 Guests (See full list)
