Help with spl score
So this past weekend I was at another competition (Surf city sound off, in Lincoln City). I scored an identical score of 136.8. I'm running (2) Rockford P3D4-12's off a P1000.1 at 34.65 volts (42.5 volts no improvement). The subs are in a ported box 2 cu/ft each before displacement, with a 4" port 13" long per woofer(divided box). Is something off because I was sure I would do closer to 140db? Big 3 upgrade has been installed. Vehicle is a 2014 Dodge Dart. Thanks for any help you can offer.
It's all about experimentation. Just keep playing with different things. If nothing is working you may want to try a different enclosure. Also, have you laid out deadener?
Yeah I'm still playing around with things. I have deadener covering all of the trunk so far(more to come). on a side note this is my 3rd box design. First box was sealed, 2nd was ported 1.75 cubes, 3rd box ported 2 cubes. thanks for the advice though.
Better dubs and more power
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I realize better subs and more power would do the trick. I'm trying to stay with all Rockford gear and also stay in the trunk 1 class, for IDBL and Bass Boxing.
I did move the box back further in the trunk, and got a nice little boost.
Read the spl gains topic that Skullz mentioned, and pay very good attention to it - there are a lot of things there that can help!
Also try a bit bigger box, like 5.6-5.8 cubes total for the two subs if you have the space. Make it one shared chamber with a single 6" or 8" aero (again if you have the space).
I've seen boxes in these type of vehicles that do good with a port to the side, but can't tell which one will be better for you, it's all about testing.
Good luck!
Build an straight up pure SPL box brotha, use that box for comps and your daily box the rest of the time...
  • Who's Online   0 Members, 0 Anonymous, 4697 Guests (See full list)
