Antoni Čović Posted September 8, 2016 Report Posted September 8, 2016 Hello, I have one question.. when bumping my sub a little bit harder it's starts to smell but a little really and it's not even hot.. is that normal for alpine?
RainStryke Posted September 8, 2016 Report Posted September 8, 2016 No, it's not normal. You are probably clipping.
DTS909 Posted September 8, 2016 Report Posted September 8, 2016 Could be glue if its new. VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
Antoni Čović Posted September 8, 2016 Author Report Posted September 8, 2016 Okay, i will turn down gain a bit then.. It's only smell on hard bass songs.. but i dont playing bass songs for long.
DLHgn Posted September 8, 2016 Report Posted September 8, 2016 I would try to meet up with someone who has a DD-1 or an O-Scope to make sure you're sending a clean signal. It could be glue (being hopeful) but it could also be you cooking your coils. Hopefully it's not that and it's just the subs breaking in but better safe than sorry.
ShadeTreeMechanic Posted September 9, 2016 Report Posted September 9, 2016 What amp are you running? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Wasteland_Audio Posted September 9, 2016 Report Posted September 9, 2016 I completely seized a type r because of a dirty signal back in the day. Didn't notice the smell because it was in the trunk. But when i went to check it wreaked like glue and voice coil.
Antoni Čović Posted September 9, 2016 Author Report Posted September 9, 2016 I dont think that i giving him clipped signal because i have two 55ah batteries and Hifonics brutus 6000d wired on 2ohm (2kw).. I probably just overpowering him a little.. mostly on bass songs it starts to smell a little bit but with normal songs no problems and even when start to smell then i turn down a little till smell goes away.
Guest Posted September 9, 2016 Report Posted September 9, 2016 if you are playing below port tuning you are going to have a bad time
RainStryke Posted September 9, 2016 Report Posted September 9, 2016 I dont think that i giving him clipped signal because i have two 55ah batteries and Hifonics brutus 6000d wired on 2ohm (2kw).. I probably just overpowering him a little.. mostly on bass songs it starts to smell a little bit but with normal songs no problems and even when start to smell then i turn down a little till smell goes away. Yeah, giving a sub twice it's rated power can get the coil stinking. I would still suggest kicking down the gain, even if it's not clipping.
