Skullz Posted September 12, 2016 Report Share Posted September 12, 2016 Could have a bad spark plug or plug wire causing the interference. Could have bad or broken grounds on the engine to the battery/chassis, big 3 usually takes care of those. Check every ground you have, including on tugging hard on wires with lugs on them to make sure they are not semi loose causing an issue. Disconnect all speakers and try each one, one at a time hooked up playing to see if you have a pinched or cut wire somewhere. This is one of those things where it is a process of elimination, and try to start at one end and work your way back 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
G-Difficult Posted September 12, 2016 Author Report Share Posted September 12, 2016 have you taken the amp out of the car and bench tested it yet? Or at least tested it inside the car without using the wiring that is in the car right now? If not get a pair of speakers and wire them directly to the amp and see if the sound is still there. No RCA input hooked up, just power and speaker wires/speakers. That's a good idea. I actually knew about that test but forgot about it. Ill try it tomorrow after work with a spare speaker. I already have a chord that I can use to plug directly into my amp. Thanks Link to comment Share on other sites More sharing options...
fordpride Posted September 12, 2016 Report Share Posted September 12, 2016 Had the same issue. Mine turned out to be the factory ground to the head unit. I ran a new ground to the firewall and problem solved. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted September 12, 2016 Report Share Posted September 12, 2016 The hiss that you hear is like static or "air"? With the engine off and rcas unplugged from the amp? Does it go away with the gain turned all the way down? If your source doesn't put out a lot of voltage, it will cause the gain to be adjusted high to compensate for the low signal. The solution is to turn the gain down and use either a source with higher output or use a pre amp to drive the line. Some EQs have a pre amp built in. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
MrSkippyJ Posted September 12, 2016 Report Share Posted September 12, 2016 He said he's tried it with the RCAs unplugged and the gain turned down. Nothing about the engine being on or off though. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted September 12, 2016 Report Share Posted September 12, 2016 With the gain lower the hiss was less. I mean turn it all the way down to see if it goes away. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
G-Difficult Posted September 12, 2016 Author Report Share Posted September 12, 2016 Just wanted everyone to know that I took it to a shop and they are pretty sure it's the amp. They told me in order for the ground to be with problem, the static would need to only be there when there is signal Link to comment Share on other sites More sharing options...
MrSkippyJ Posted September 12, 2016 Report Share Posted September 12, 2016 With the gain lower the hiss was less. I mean turn it all the way down to see if it goes away. I actually missed where he said it was less, my bad! F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
