ShadeTreeMechanic Posted September 21, 2016 Report Share Posted September 21, 2016 Arm chair builds are the best! 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted September 22, 2016 Report Share Posted September 22, 2016 Arm chair builds are the best! You really must appreciate mine then, I haven't had a system in years, I've just been slowly piecing one together the whole time, Sucks being poor but even if it takes me longer to get it all I won't sacrifice what I want and get cheaper stuff just so I can have a system. Only difference between me and op is I'm not a noob, lol. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted September 22, 2016 Report Share Posted September 22, 2016 Yeah, I do my share of arm chairing too. I also know that there is too much to learn to start at the top. To me the build is the best part and I will never be finished. It just wears me out seeing helpful people answer a seemingly endless amount of questions about something so subjective. I bet what ever op ends up with, he won't be satisfied with it. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted September 22, 2016 Report Share Posted September 22, 2016 Yeah, I do my share of arm chairing too. I also know that there is too much to learn to start at the top. To me the build is the best part and I will never be finished. It just wears me out seeing helpful people answer a seemingly endless amount of questions about something so subjective. I bet what ever op ends up with, he won't be satisfied with it. And that's the story for all of us, no matter what we do and what kind of gear we have we always always always end up changing stuff. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
06RTCharger Posted September 22, 2016 Author Report Share Posted September 22, 2016 Well if you want to be different and try to help advance things then you'll probably have to take some risks, $2k isn't an expensive gamble for a whole system, You could easily drop that on a single amp alone, You're getting a head unit, dsp, mids, highs, and subs, for that price with the clarion setup. Someone has to guinea pig it, why not you if you got the money to play with? Yah its not alot for a WHOLE system. I just dont know if id like the output capabilites of it. Speacially with the speakers. But i found out a local shop is an authoirzed dealer of clarion here, im gonna go check out that nx706. Hopefully they have it set up. And nah, im good in the guinea pig situation lol. Link to comment Share on other sites More sharing options...
06RTCharger Posted September 22, 2016 Author Report Share Posted September 22, 2016 Yeah, I do my share of arm chairing too. I also know that there is too much to learn to start at the top. To me the build is the best part and I will never be finished. It just wears me out seeing helpful people answer a seemingly endless amount of questions about something so subjective. I bet what ever op ends up with, he won't be satisfied with it. Armchair bulid? Im assuming that means that all the person is doing is dreaming things up? Dont be so bothered by questions, im trying to learn, i dont want to walk into things cluelessly. I like to have a decently solid plan before approaching anything. Lol. Ill be sure to post my build soon as it starts. First will probably be deadening+running wires, if not it'll be the HU first if i decide on that nx706. Really hoping on that HU to be good. Ill keep u posted buddy lol. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted September 22, 2016 Report Share Posted September 22, 2016 I'm not trying to be rude, I know you have a lot to consider. You are on the right path and I look forward to seeing pictures of your build. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
