ShadeTreeMechanic Posted October 10, 2016 Report Posted October 10, 2016 Just saw the vid. Looks good for 800w. Might get a little more by moving it closer to the back of the trunk. Like 6 inches maybe. I would be curious to see if it helps. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
ModestDb Posted October 10, 2016 Author Report Posted October 10, 2016 Just saw the vid. Looks good for 800w. Might get a little more by moving it closer to the back of the trunk. Like 6 inches maybe. I would be curious to see if it helps. It did. I actually tried that after the video and it helped a lot. It's just amazingly loud now. 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
Joe X Posted October 10, 2016 Report Posted October 10, 2016 Just saw the vid. Looks good for 800w. Might get a little more by moving it closer to the back of the trunk. Like 6 inches maybe. I would be curious to see if it helps. It did. I actually tried that after the video and it helped a lot. It's just amazingly loud now. Glad you liked the box, thanks for caring and taking the time to post pics, vid, etc for us.
ModestDb Posted October 11, 2016 Author Report Posted October 11, 2016 Just saw the vid. Looks good for 800w. Might get a little more by moving it closer to the back of the trunk. Like 6 inches maybe. I would be curious to see if it helps.It did. I actually tried that after the video and it helped a lot. It's just amazingly loud now. Glad you liked the box, thanks for caring and taking the time to post pics, vid, etc for us. It was fun to do. I might actually solicit your advice again soon for a box for 2 American Bass XD 12" subs. My niece heard mine and wants some bass in her Honda CRV. Anyway... do you have a paypal account? 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
ModestDb Posted October 11, 2016 Author Report Posted October 11, 2016 im showing you about 38hz you can just play test tones at moderate volume, start at about 45 and work your way down, watch the sub, when the cone moves the least amount, that is your tuning. Also thank you too for the help earlier on in this thread! 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
ModestDb Posted October 11, 2016 Author Report Posted October 11, 2016 Told ya a better box was going to make a significant difference :-) And thank you for all the helpful information too. Very appreciative for that! 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
DLHgn Posted October 12, 2016 Report Posted October 12, 2016 Glad to hear it turned out the way you wanted and then some. Nothing like having the finished product do what it was intended to do and then surpassing that. Too many people don't understand the importance of a proper enclosure to accomplish the set goals. You can have the biggest baddest sub in the world but if it's in a crappy/inappropriate enclosure, it probably won't perform as well as a crappy sub in a proper box.
