Jessica Posted October 9, 2016 Report Posted October 9, 2016 I was going to say. I thought area was determined by power. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
ChevyBoy95 Posted October 9, 2016 Report Posted October 9, 2016 I was going to say. I thought area was determined by power. Amount of air that can be displaced by the cones I thought. Power can dictate it though, because at 100% power in theory 100% xmax, you will have 100% displacement, at 50% power, you might only have 60% displacement, etc. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Jessica Posted October 9, 2016 Report Posted October 9, 2016 I was going to say. I thought area was determined by power. Amount of air that can be displaced by the cones I thought. Power can dictate it though, because at 100% power in theory 100% xmax, you will have 100% displacement, at 50% power, you might only have 60% displacement, etc. yes, cone area plays a part. But if you have 4 250 watt 12's, or 4 5k 12's the port area will change vastly. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
hdorre Posted October 9, 2016 Report Posted October 9, 2016 yes, cone area plays a part. But if you have 4 250 watt 12's, or 4 5k 12's the port area will change vastly.yes, volumetric displacement has an immense affect on port velocity. power is an additional factor as well, like you previously stated. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
DLHgn Posted October 9, 2016 Report Posted October 9, 2016 So many wrong things were said in this thread. That in^2 to ft^3 rule of thumb is not accurate at all. Krakin, Chevy, Strange and hdorre for sure know what they're talking about. Sorry BMS but you must have been misinformed at some point.
akuma4u Posted October 16, 2016 Author Report Posted October 16, 2016 ok i need some confirmation - in the attached pic, the area circled red, that value should be under 10 in order to prevent port noise.. is this correct? also - whats the difference between port compression vs port velocity? if the % of mach is under 10 is that all i need to worry about?
Joe X Posted October 16, 2016 Report Posted October 16, 2016 0.10 may take care of noise but you may still have compression, you want to be like 0.05 or below for an efficient port, specially slot ports where you have sharp edges and turns.
akuma4u Posted October 16, 2016 Author Report Posted October 16, 2016 So the 5 i have in red circle is the same as 0.05 Correct?
Jessica Posted October 16, 2016 Report Posted October 16, 2016 Maybe i dont understand, but from what i have seen and read, port noise is just a thing you will have in a car if you are running any kind of mid to high end drivers. You simply dont have the room in most vehicles to get proper port area. I Think most people would never even hear port noise over what the subs are doing and most your noise is going to happen right at tuning where your port is doing all the work anyway. But i could be wrong, its happened before. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Joe X Posted October 16, 2016 Report Posted October 16, 2016 So the 5 i have in red circle is the same as 0.05 Correct? W is acoustical power not electrical power so that result is invalid, that said those formulas are not as reliable as modeling curves, some 35-37 square inches of port area would be good enough for the 40Hz you want.
