BMS Posted October 12, 2016 Report Posted October 12, 2016 I bought a pair of crunch drive series 15's (ds-15) in a box for 10$. They have about 1.2 cu foot per sub in a sealed box. They fail at low frequencies because of their extremely limited excursion probably 6-8 mm and they make virtually no sound from 40hz-60hz and they only get loud at above about 100 hz. They say 350 watt I think that is an rms claim but it doesn't specify. I am also assuming that they were produced in different years because they have different magnet structures. Are these subs really that bad I gave them plenty of power (600 watts rms) and the box is sealed fairly well i checked inside and cut some carpeting off to check.
Triticum Agricolam Posted October 13, 2016 Report Posted October 13, 2016 They could be wired out of phase, or there could be a leak in the box. I'd check those things first. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
BMS Posted October 13, 2016 Author Report Posted October 13, 2016 Can't be out of phase if they are in series unless there was other the circuit can they? so long as the polarity is correct as well. If there is a leak it is the size of a screw hole at best it is fairly well sealed now. But yeah now that you say it they did sound like what i would imagine they would if they were out of phase. How might switching the polarity sound if i had done that by accident?
ckeeler11 Posted October 13, 2016 Report Posted October 13, 2016 If the wiring is good and the box is good that leaves only one piece... the subs are garbage.
Jessica Posted October 13, 2016 Report Posted October 13, 2016 As old as those are I wouldn't be surprised if they need 2cuft per sealed Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
ckeeler11 Posted October 13, 2016 Report Posted October 13, 2016 Specs for subs http://www.maxxsonics.net/manuals/crunch/pdfs/crDRFB_DS10E-15E.pdf
BMS Posted October 13, 2016 Author Report Posted October 13, 2016 tahnks for the manual i checked everything and they still arent any good at 40 hz i probably have like 75-80 db.
Kyblack76 Posted October 13, 2016 Report Posted October 13, 2016 That 6-8mm of throw though. Jesus, my mid range pa drivers in my door threw twice that far lol. They sound like they are sme beast drivers lol. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
