Ok so i need advice from the pro's for my build! I currently have 2 12's in a 6 Cube ported box, now in order to make more room for my aux batteries and 4 channel amp i will be adding i was wondering if this would be the one exception to front firing a subwoofer box. I was going to build a platform to set the box on which would leave no gap between the roof and the box, I was also going to seal the 2 inchs on each side off as well. So in this repect i could put my batteries and four channel underneath the sub box by letting the platfoor have a higher back the subs would be above the rear seats pointing forward would this result in a good positioning of the subs i currently have the subs facing up[ and ports up i would of liked to have subs up ports back but i would of been choking them off if i would of done so. Its ok if its a fucked idea i can handle it.
2012 Kia Soul
 Infinity reference 6.5's  Coaxials
2x Soundqubed HDS312 @ 32hz (hdx312 waiting on alt)
1x Skar Audio RP-2000 (deaf bonce 4k on floor waiting on alt)
1 x Northstar group 35 front
1x Nortstar SMSAGM220 rear (have a second one waiting on alt)
0 gauge Sky High OFC
BIG 4
post a pic of your current system and maybe a sketch of your idea, it sounds like you are going to end up building what essentially looks like a full wall but only half of it is actually a speaker box
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
its 5 cubes my bad lol typo its 2 soundqubed HDS312s 2.5 cube per sub.
2012 Kia Soul
BIG 4
No reason you couldn't do that,
Your essentially building a full wall but only half of it is going to be the actual enclosure and the other half is just to house the gear,
I see no issues whatsoever with that.
You really don't have many other options in a car that small unless you get rid of the rear seats.
yeah i have a son otherwise id be doing a b pillar wall lol, but from what i understand as long as its sealed off from the subs back it wont lose any performance, Im currently in the process of sealing off the bottom of the hatch because the air that gets pusshed down there adds a rough sound to the bass, i also just finished deadening the roof, has anyone used closed cell foam between the roof and headliner to prevent the headliner from slapping?
2012 Kia Soul
BIG 4
  • Who's Online   1 Member, 0 Anonymous, 1566 Guests (See full list)
