crownvictoria31 Posted November 14, 2016 Report Share Posted November 14, 2016 I have a question. When an amp is all hooked up and powered up, is it suppse to spark if you take a wire and touch the outside portion of the rca input and the other end of the wire to the amps casing? Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted November 14, 2016 Report Share Posted November 14, 2016 This being a question tells me you did it and it sparked, which has me wanting to ask why the hell you'd do something like that anyways? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
crownvictoria31 Posted November 14, 2016 Author Report Share Posted November 14, 2016 It was not me. My friend was installing his sound system and did this thinking this would help other then removing his radio and grounding the rcas behind the pioneer unit. Now im questionning because ive never seen this happen. Is it suppose to spark like this? Link to comment Share on other sites More sharing options...
whazoo84 Posted November 14, 2016 Report Share Posted November 14, 2016 I have a question. When an amp is all hooked up and powered up, is it suppse to spark if you take a wire and touch the outside portion of the rca input and the other end of the wire to the amps casing? Short answer is yes and no. This can happen, but if I saw this happen I'd probably have the amp or head unit (or processor if you have one) checked out. The amount of energy required to generate a spark isn't too big, but it's definitely enough to do some damage. What you probably saw was the RCA outputs of the head unit finding their way to an earth ground, which they are NEVER supposed to be hooked to. If it happened for a quick second you might be good, but I wouldn't chance it. Have the thing checked out. Or if you wanna be brave (and I take no responsibility for this) go ahead and plug it into the amp and see what happens. It could work fine, but as I said before, do anything at your own risk. The other really rare scenario is a grounding issue inside the amplifier. You see, amplifiers have MOSFETs and transistors inside them, most of which have metal backings that are live hooked directly to the + rail from the power supply of the amplifier. If one of these happens to find it's way to ground (if it's a cheap amp and they put too much thermal paste on it, that stuff can be conductive depending on the type and this can cause the transistors to ground through a slight resistance). There's other ways for that to happen, but if it does happen you need to unplug the amp right away as it's a serious fire hazard. Just be careful, also can you tell us what head unit + amplifier you're using? How did you hook them up? Some info on what your build is could really help us help you. Link to comment Share on other sites More sharing options...
crownvictoria31 Posted November 14, 2016 Author Report Share Posted November 14, 2016 Well he has a pioneer headunit. Cant remember the model. As per the amo, its a 2 channel hifonics amp for his mids. I understand what your saying and with what you said, im going to say that his amp is defected. Im saying this because with out rcas being hooked up, he touched the rca input on the amp and the amp casing as well and it still sparked. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted November 14, 2016 Report Share Posted November 14, 2016 Sounds like the amp ground isn't very good and it is seeking a ground through the RCA shield. The RCA shield is grounded inside the head unit. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
MADVIBES Posted November 14, 2016 Report Share Posted November 14, 2016 if its a pioneer the pico fuses are for sure now blown, engine whine here we come. an earlier post said the negative on an rca is never supposed to be shorted to the earth but thats not exactly true, it all depends on the arcitechure of the design. his amp may have sparked because he has a bad ground where the amp is and its finding a better through the head unit. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted November 14, 2016 Report Share Posted November 14, 2016 I have heard of bad amp grounds burning up the rcas. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
