Just a thought. Consider gluing strips of sturdy wood to the floor before you apply the D pro, then put D pro everywhere else. I have had success doing this with strips of oak and PL adhesive. Then attach your amp board to the strips of wood that are glued to the floor or wall metal. This will allow you to avoid drilling holes in your floor. If not possible please disregard.
I believe his point of putting it on the D pro is that he didn't want to stick anything to the floor just in case he needs/wants to pull it up. Easier to remove the D pro than to remove a piece of wood attached by PL.
But i might be doing the technique that someone mentioned a lil while ago about bending a flat bar to shape and mounting that the the seat rails. I still have to check out my seats if its possible.
Might still try the epoxy for other amps/locations
Edited by 06RTCharger
I wouldn't be so quick to assume that it will be easier to remove, second skin is not easy to remove at all, once it's stuck it's not meant to come off easily.
  • Like (+1 Rep) 3
I have my 4 channel amp on the floor behind the passenger seat not even mounted down lol. Just through some blankets over it so I don't get jacked =_=. It doesn't even over heat!
I would be concerned with that, in the event of an accident, it would become a projectile. I know it's under a seat but if it were to fly forward it could hurt someone in your passenger seat. I mean at the end of the day it's your car/amps/passengers but just as a thought to consider.
