Ext cab window rattling.
Stop being so loud? Find where the window is making contact and try putting like a foam or dampening material there? Maybe around the whole rim of the window if you can. I'm really not sure, just spit balling here.
I was thinking about using some of that window foam stuff at home depot or should i use that seal stuff they use on windshield repair ? I dont care if i seal them shut. I dont ever open them anyways
Second skin makes a rope type deadener that would work perfectly.
Ordered it cant wait to stop that damn rattling. Thanks guys
Post if it works. I have the same issue
I took silicone and sealed mine to where they can no longer open and it worked fine in my 95 chevy.
Which silocone ? I'm willing to do that tomorrow
regular black silicone worked fine up until I had 2 15's on 7k at the windown line, then I PL'd them shut and they are still held tight.
So I should go right to the PL :) 8x ?
