is there any difference between these port designs??
oldsoundguy
I want to know which one of these port designs would be better or is there any difference??
Are they the same?? I want to build a box for a single 8 and want a net of .75 tuned to as close to 35HZ as I can get.
I used Torres design and every size box I try it calls for a two bend port. So I was wanting to know if there is a difference between these two drawings of the ports??
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Box #1 would be my preference since it avoids the 180 degree bend box #2 has. 180 degree bends are worse for efficient airflow.
Builds:
Thank you so much for your response. I will absolutely take your advice.
80prs
DC 180 alt
what are the possible real world differences in those? IE if I built both and listened to them back to back, what would I notice in difference between them?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Is this new drawing of number 3 box possible?? each slot would be the same width 1.5" and would still get my 30" physical port size.
Just wondering is all. I have been searching the web for the last week or so and really cant find any information.
80prs
DC 180 alt
Ok well I decided to change everything up. I was trying to use a box I had that was going to be 13.5 H 20 W and 11.5 D and I just couldnt get it designed without 2 bends in the port. So I am building a new box that will allow only one bend in the port so just a basic L port now.
Thanks for the responses.
If you want to see the box I built go check out my build thread in the link below. Page 54
Thanks
80prs
DC 180 alt
click link
80prs
DC 180 alt
  • Who's Online   0 Members, 0 Anonymous, 1978 Guests (See full list)
