Need some help on electrical
Hi guys i have currently started a project on my car and just need some help on what cables and fuses to use and how to wire them.
Right so my setup is going to be 2 Zv5 15's running on a SCV-6000D wired to 1 ohm the car has a 210 HO alternator on it and the battery setup is 1 standard starting battery looking to upgrade to a XS power for the front in the future and have 2 Odyssey PC2150S for secondary.
What i need to know is what wire size i need for the battery runs and amp was thinking Sky high 1/0 and what fuse size i need and how i connect it all up including grounds.
And also is says i need a 500A fuse for the amp is that for both cables as it has 2 power connections or do you split it and run 2 250A as there 2 cables.
If someone could do a diagram of it all it would be awesome.
Do some research and figure it out, you'll get nothing but mixed answers here and you'll be left even more confused.
I will tell you this, one 210amp alt and just the under hood battery will not be enough to properly feed that amp.
Three to four + runs of 1/0 from the front to the back will be sufficient.
I wouldn't use sky high....
Inb4 the you fuse for the wire guys.
I'd get Knu cables instead:
http://www.knukonceptz.com/
Sky High is cheapest for a reason.
1 run of 1/0 gauge OFC will get you 375A max.... I would fuse each run for 250A or run both runs to a 500A fuse holder, either way should work just fine.
As for your electrical set-up. You are going to need more battery reserve... like 6 group 31's.
I almost bought an SVC6000 a while back. Make sure you fuse the cables at both ends. Fuse at front battery and at rear battery so if a cable gets pinched in an accident, the fuses will blow to disconnect the batteries. At least 3 runs of + 1/0 and one run of - 1/0. What car? Get a volt meter and use the volume knob to keep it above 12v. Try to post some pictures if you can.
Pioneer 80PRS
If all he has is that alt and cheap battery up front 4 runs will do nothing more than what a single run can do.
Upgrade your front battery and do a single run from the front to the back. Get some more bits from the back. That is where you should run 2 sets of positive and negative to the amp, from the back batteries
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
So it can't attempt to pull more current from the front battery because the alt isn't making it?
So if your theory is correct how can it do so from the rear batteries?
Because if all he has is 300a or around that of possible current in the front, adding more wires won't make him be able to pull any more amperage he doesn't have. From the back battery back though on an amp that requires dual inputs, that is where doubling the wires is not only necessary but will help. If all his power can from the front, then doubling the wires would help.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
The amp will try and draw all the current it wants regardless of what that alt is putting out.
Right so i got mixed answers on this as i think some of you didn't know i already had extra batteries.
My current setup is
Electrical
1 210 HO alternator with a external voltage regulator set to 14.6v ( was the biggest i could get on the car )
standard starting battery ( looking at upgrading to XS power one in the new year )
2 Odyssey PC2150S for the rear
Subs and amps
2 Zv5 15'' D1 wired down to 1 ohm
1 SCV-6000D
How many more batts would you recommend as one guy above said 6 bare in mind this is going to be a daily car so won't be driving around full tilt all the time and also i don't think the system will ever see the full 1 ohm because of rise.
  • Who's Online   0 Members, 0 Anonymous, 4539 Guests (See full list)
