Alternative to foam for roof bracing? (pics included)
I see a lot of people using foam to stop their roof from slamming into the braces while flexing.
Since I don't have any foam, but do have rubber, I'm thinking about placing that between the bracing.
Does anyone know of any reason NOT TO use rubber? Or any pros of using foam over rubber?
I second the vote for PL. Glue the ribs to the roof and never worry about it again.
Pioneer 80PRS
People usually use foam when they wall, not just to stop those braces from hitting the roof.
The rubber will stop that, but wont stop the roof flex.
PL and wood on the roof works wonders.
If your gap between the wall and the roof is tiny it can work decent too, but its best to do it in small sections.
If you try to do it all at once the foam gets hard on the outside, but not the inside and creates a suction which cause the roof to dimple.
I'm talking about foaming the braces like such:
(Canag3's S-10 Blazer w/ 2 18s).
I understand that people walling use foam to seal off and prevent air from escaping, but I'm speaking strictly towards preventing the roof from smashing into the braces.
My plan would be to put rubber inbetween all of the braces and the roof, and then use Second Skin Damplifier everywhere else on the roof.
Wouldn't this cause warping issues? I thought that with all the vibrations, having anything super rigid would be a bad idea.
The PL will bond the roof to the braces unlike anything you have ever used, and as audio has said you can also bond MDF sheets to the roof in the same way with the pl to prevent roof flexing.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   1 Member, 0 Anonymous, 1328 Guests (See full list)
