XS Power
16 hours ago, SnowDrifter said:
Lithium and lead/acid are going to have different resting/usable voltages. Based on what you described I suspect the lithium rests a bit higher than the d3400
Where are you load testing/reading voltage from?
Did a multitude of places trying to see if he had some parasidic drop in current or voltage from a bad ground.
On 1/20/2017 at 10:49 AM, reedal said:
Did you clamp the current from the lithium to the amp(s)? The alt may only be outputting 85 because it only needs to make 85....
Pulling 325 dynamic
with load tester it was pulling 400 and only putting out 85....
  • 3 months later...
