XS Power
So a buddy of mine was tired of having a heavy bank of batts in his VW so he decided to go with an xs 36k spl this year.
We hooked up the lithium in the back and also left his d3400 upfront. Went out and tested hoping for some better voltage also.... well it was worse....
We started with clamping the alternator (6 years old and may have needed a refresh) and it was clamping 85 amps with the amp pulling a load.
Messaged Mr. Singer and a few others and he said to go get a load tester and try the test again.
In the testing we found that the alt was making 85 amps at idle when it was claimed to make 200. Also then we put a load on it and it put out 95 even under a load of 300 amps.
We were ready to pull out the alternator and then someone suggested to disconnect the lithium and try it. We did that and alt was able to put out 175 at idle....
Messaged scotty to see what he thought and he told us to do the same and disconnect the d3400 and see what the alt clamped. Did that and it clamped 175 amps.
So we decided to ditch the d3400 this year but before we pulled it we decided to clamp the run that went from the lithium to the d3400 and we found that under a load the lithium was actually feeding the 3400 before the alternator was. We found the alt was still putting out the 85 amps but the lithium was pushing amperage to the d3400 (120 amps of current)
Anyone have a good explanation for this? Just trying to gain some knowlede. We plan on pulling d3400 and putting it in my truck and put a bank or 2 of caps in a d3400 case up front in the engine bay in his car
31 minutes ago, Kyblack76 said:
What was your voltage like at all this  testing? Is it down?
Originally he had 2 xp3000s off of a sundown 6k and was seeing 12.4 full tilt
with the d3400 hooked up and the lithium he was seeing 11.5 full tilt.
we are going to test this weekend with no d3400 just the lithium
hunter had a similar result when he added his winston. his front batt was outputting 80a while his winston was outputting ~800a. due to the agm's lower resting voltage, it would drain the lith when the car was off, so there was no reason to keep the batt up front. he wound up bypassing it. its been like 3 months, no issues.
as far as the alt not outputting full power under load, i cant help ya. as much as scottie hates his guts, this may be a question for someone like Travis Young of JY.
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Lithium and lead/acid are going to have different resting/usable voltages. Based on what you described I suspect the lithium rests a bit higher than the d3400
Where are you load testing/reading voltage from?
bend over.
  • Like (+1 Rep) 2
LMFAO so true
:blush:
IN4 Wisdom.........
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
We isolated batteries so that his lithium would only be connected to battery system when car was turned on. This is done to help the battery resting voltage. Didn't wanna drain the lithium down to 12.8 when its happiest at 13.4
  • Who's Online   0 Members, 0 Anonymous, 1228 Guests (See full list)
