Ron36 Posted February 4, 2017 Report Posted February 4, 2017 My alpine type R's say 65hz to 25khz is this correct for my amp setting for frequency http:// 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
Skullz Posted February 4, 2017 Report Posted February 4, 2017 If your using the passive crossover you'll want to set the switch to AP so all frequencies go through. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Ron36 Posted February 5, 2017 Author Report Posted February 5, 2017 Thanks I was gonna be on HP 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
Jessica Posted February 5, 2017 Report Posted February 5, 2017 The passive won't block bass from the mids. So use the hpf on the amp. You look like you are in the basllpark. You can always tweak it late. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Ron36 Posted February 5, 2017 Author Report Posted February 5, 2017 I will use the HP I thought that was right and then just tweak while playing thanks 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
06RTCharger Posted February 5, 2017 Report Posted February 5, 2017 Type R. Isnt that a sub? 65-52 hz recommended crossover frequency sounds like a sub setting. For a sub you use LowPass, so the lows pass through and the highs above ur setting gets tappered off. but your title here says amp on mids, so maybe part of ur post didnt show up on my screen(that happens sometimes for me). If it is for midrange woofers, disregaurd everything i said lol.
Jessica Posted February 5, 2017 Report Posted February 5, 2017 They make type r and s coaxial and components as well Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Ron36 Posted February 5, 2017 Author Report Posted February 5, 2017 6.5 component set 65Hz to 25KHZ http:// Sorry it's upside down 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
06RTCharger Posted February 5, 2017 Report Posted February 5, 2017 Also that dot between 50hz and 125hz, where ur set at in the picture, should be 87.5hz. Thats the middle of 50-125. But thats assuming a potentiometer dial is accurate, which i wouldnt bet on, it should be decently close tho. Just know that dot "should" be 87.5hz. Then the imaginary middle point between 50hz and that dot (87.5hz) should be 68.75 hz. So based on that theory, 65hz would be barely closer to 50hz, rather than being closer to the dot(87.5).
06RTCharger Posted February 5, 2017 Report Posted February 5, 2017 Oh ok yup disregaurd, my bad. Thats some nice mids they can be set down in the 20s.
