Rich Schenk Posted February 8, 2017 Report Posted February 8, 2017 Just wondering because I am getting mixed answers on this on fusing 4 runs of SHCA ofc 1/0 to my back battery bank what fuses do I need for each run? I have a singer 340 amp alt d3400 and 4 d3100s in the back. I'm thinking 4 100 amp fuses On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
reedal Posted February 8, 2017 Report Posted February 8, 2017 All youre going to get is mixed answers here too. Fuse for the ampacity of the wire for the length of the run, or fuse for the amps current draw ratings. Either way you go, dont fuse higher than the wire can handle, and you should fuse for less than the max. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
xile Posted February 8, 2017 Report Posted February 8, 2017 6 minutes ago, reedal said: All youre going to get is mixed answers here too. Fuse for the ampacity of the wire for the length of the run, or fuse for the amps current draw ratings. Either way you go, dont fuse higher than the wire can handle, and you should fuse for less than the max. spot on!
Rich Schenk Posted February 8, 2017 Author Report Posted February 8, 2017 Regardless though amps would pull from rear bank regardless, and being that alt only puts out 340-340+ wires total shouldn't see more then 400amp pull correct because of alt Max amperage or am I wrong? On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Kyblack76 Posted February 8, 2017 Report Posted February 8, 2017 Just because your alt only does whatever, you also have around 500 amp hours in your bank. Fuse for the wire cap, stick a 250 or 300 on each, on both ends near the bat(s), done. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Rich Schenk Posted February 8, 2017 Author Report Posted February 8, 2017 Ty kyblack will go with what u say On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
White Lightning Posted February 8, 2017 Report Posted February 8, 2017 Having 4 runs, you divide the power by 4 ... Correct ??? So you're not going to have max draw per run ... Correct ??? You definitely do not want a too large of a fuse and it not do you any good in case of a problem ... Correct ??? I would do what you said from the start and go with a 100 amp fuse on each ... Which gives you 400 amps worth of protection ... Only move up if needed ... Just a suggestion Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
Rich Schenk Posted February 8, 2017 Author Report Posted February 8, 2017 That was what I thought as well seeing that the Altenator is only outputing 340-380 Max On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
White Lightning Posted February 8, 2017 Report Posted February 8, 2017 I could care less what the alternator does, it's what the amplifier(s) draws / needs to operate safely ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
Rich Schenk Posted February 8, 2017 Author Report Posted February 8, 2017 dc 5k draws 500amps max Mmats sq4100 says 30 amp online not with car to double check Skar 85.4 60 amps worth of fusing so just total them would be around 600 amps just wanting to know the logic behind this already have 3 200s now cause only have 3 runs currently On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
