Fusing on multiple runs
Just wondering because I am getting mixed answers on this on fusing 4 runs of SHCA ofc 1/0 to my back battery bank what fuses do I need for each run? I have a singer 340 amp alt d3400 and 4 d3100s in the back. I'm thinking 4 100 amp fuses
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
All youre going to get is mixed answers here too.
Fuse for the ampacity of the wire for the length of the run, or fuse for the amps current draw ratings. Either way you go, dont fuse higher than the wire can handle, and you should fuse for less than the max.
spot on!
Regardless though amps would pull from rear bank regardless, and being that alt only puts out 340-340+ wires total shouldn't see more then 400amp pull correct because of alt Max amperage or am I wrong?
Ty kyblack will go with what u say
Having 4 runs, you divide the power by 4 ... Correct ??? So you're not going to have max draw per run ... Correct ???
You definitely do not want a too large of a fuse and it not do you any good in case of a problem ... Correct ???
I would do what you said from the start and go with a 100 amp fuse on each ... Which gives you 400 amps worth of protection ...
Only move up if needed ... Just a suggestion
That was what I thought as well seeing that the Altenator is only outputing 340-380 Max
I could care less what the alternator does, it's what the amplifier(s)
draws  / needs to operate safely ...
dc 5k draws 500amps max
Mmats sq4100 says 30 amp online not with car to double check
Skar 85.4 60 amps worth of fusing
so just total them would  be around 600 amps
just wanting to know the logic behind this
already have 3 200s now cause only have 3 runs currently
  • Who's Online   1 Member, 0 Anonymous, 2218 Guests (See full list)
