Shelbywh89 Posted February 11, 2017 Report Posted February 11, 2017 I have a question I'm looking to do a build with three Level 4 Dc 15's so I need a box 9Cuft in the trunk of my old school G body. The place i talked two wants to do 3 single boxes and put a beauty panel over the front to make it look like one big box. Will this work and be okay?
Joe X Posted February 11, 2017 Report Posted February 11, 2017 Is there a reason to do 3 separate boxes instead of one? It will result in a heavier, larger setup with no meaningful difference in performance. Could you be more specific on which exact car and what's the plan? 3 15s need a pretty large vehicle to fit properly.
Wasteland_Audio Posted February 14, 2017 Report Posted February 14, 2017 I had a 79 Malibu so i know from experience that those have a lot of trunk. However I don't really believe there will be much benefit in doing 3 separate boxes unless the issue is getting it in and out of the trunk. you would be much better off building the enclosure permanently inside the trunk as one chamber.
ShadeTreeMechanic Posted February 14, 2017 Report Posted February 14, 2017 How do you put four subs in three boxes? Sounds odd.... ported or sealed? Ported would be even more strange. Sounds like they are going to grab three pre fab boxes and throw them in there. I would take it somewhere else. Edit: 3 subs my bad I can't read. lol 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
1gggman1 Posted February 14, 2017 Report Posted February 14, 2017 3 15" Dc's in a Caddy? Very cool, sounds line you need a shoehorn! Yes, it will work well... Sounds like a Mustang I did once...with usable trunk space but had no rear seat access into the trunk and a relatively small trunk opening at the lid! Seperate enclosures? It can be done, just make sure the shop ties them together really solid... Really everyone should know that 15" Dc's usually are powered by some real power and venting them into the cabin somehow will not be a bad idea... Just make sure the installation shop is on the same page. Dynamat can only help so much! Love those Caddys!
1gggman1 Posted February 14, 2017 Report Posted February 14, 2017 Wait a minute you said 4 subs in 3 boxes? Hell, same principle... Don't sacrifice airspace to fit them.... in you'll not be very pleased with the result. It might look pretty and knock... But will it SUB? Later...
