Amp not getting enough power?
cheatcode
aside from the fact that you are just arbitrarily turning your source down so you can for some reason turn the gains higher on your amp, have you considered that your amp just might be fucked up?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
mrskippy, as i've said before, my amp is not the issue.
what i'm doing isn't arbitrary at all, nobody who's running even a half decent setup is going to set their gains with their volume at 100% just because their hu doesn't clip there. you set it at 3/4 or maybe a little bit higher because if you set it at full volume and run an RTA and have to boost any frequencies at all you could potentially be clipping them and then you're left with absolutely 0 headroom. arbitrary is setting your volume at full blast to get more voltage when your volume is set to 100% because you think that's giving you some huge advantage.
  • Who's Online   0 Members, 0 Anonymous, 1512 Guests (See full list)
