18Sound Eighteen vs Sundown Fifteen
Generally I'd argue that the subwoofer with the highest power handling and the most displacement will generate the most output.
But there are some prosound drivers that have so much motor force, they basically allow you to 'go up a size' because the BL is so high.
So even though they have less XMAX than a typical car audio sub, their high BL might make up for it.
Only one way to know for sure, so let's do some sims.
Here's our contenders. 18TLW3000 from 18Sound, and Sundown X15 D2
Here's the specs :
retail price: $480 vs $550
SD: 1210 vs 729
xmax: 12mm vs 30mm
displacement: .145 liters vs .219 liters
voice coil diameter: 7.5cm vs 10cm
RMS power handling: 3600w vs 1500w
Based off his other threads im guessing hes going to post test results from his own testing of both the subs.
I wanna see that 18 take 3k all day like that sundown could
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
I'm in to see results hopefully some video
Im down to see some testing also.
I checked out eighteens website , looks like u build your sub but was very wierd. Was trying to see there better models
  • Who's Online   0 Members, 0 Anonymous, 711 Guests (See full list)
