bolanorthhighlands Posted April 3, 2017 Report Posted April 3, 2017 I have a box with (4)8" speakers. I want to make my (4)8" box into a (2)12" box. I was going to use half inch thick mdf to seal the (4)8" speaker holes (the total outside depth would be 15". The inside depth would still be 12"). The box has (2)6" holes. I wanted to ask how long of a 6" port would I need for my (2)12s? It looks like it says (2)20" long ports. The port will be mounted outside of the box. Or I can seal one of the 6" holes and mount one 8" long port. My 2002 Kia Spectra LS My YouTube Channel
ShadeTreeMechanic Posted April 3, 2017 Report Posted April 3, 2017 What kind of power are you going to run to them? Are you sure you want 45hz? That will make the kick drums loud but will not have much low bass. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
bolanorthhighlands Posted April 3, 2017 Author Report Posted April 3, 2017 Hifonics 35th anniversary colossus 2x1700rms at 1 ohm. The paper said 47hz that's why I chose 45hz My 2002 Kia Spectra LS My YouTube Channel
ShadeTreeMechanic Posted April 3, 2017 Report Posted April 3, 2017 Are the subs single voice coil or dual voice coil? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
bolanorthhighlands Posted April 3, 2017 Author Report Posted April 3, 2017 Dual 4 so maybe I'll get 2x1200rms on that amp My 2002 Kia Spectra LS My YouTube Channel
Joe X Posted April 4, 2017 Report Posted April 4, 2017 4 hours ago, bolanorthhighlands said: Hifonics 35th anniversary colossus 2x1700rms at 1 ohm. The paper said 47hz that's why I chose 45hz Fs is the free air resonant frequency of the driver not tuning instructions.
bolanorthhighlands Posted April 4, 2017 Author Report Posted April 4, 2017 oh.. i thought i had to build my box to those specs to get the best performance out of my subs My 2002 Kia Spectra LS My YouTube Channel
ShadeTreeMechanic Posted April 4, 2017 Report Posted April 4, 2017 If you could do a single external six inch port at 17 inches long, it would give you 34hz. If you did internal, you would need to make it 20 inches for 34hz. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
bolanorthhighlands Posted April 4, 2017 Author Report Posted April 4, 2017 But if the vas was a recommended enclosure. Would it be sealed or ported? I can change my fs to any frequency I want? My 2002 Kia Spectra LS My YouTube Channel
Triticum Agricolam Posted April 4, 2017 Report Posted April 4, 2017 57 minutes ago, bolanorthhighlands said: But if the vas was a recommended enclosure. Would it be sealed or ported? I can change my fs to any frequency I want? Vas is a measurement of suspension compliance, its not a recommended box volume. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
