DRAMAQUEEN Posted April 28, 2008 Author Report Posted April 28, 2008 Rather then just using resin I would cut 45's out of mdf and then lay matt on top of that, it will save on resin. And allso if you mix your resin right it doesnt take too long to dry, mine normally is dry with in 2-4 hours depending on the weather. I was thinking that to.. just cut the 45's then throw a few coats of resin on the entire box? ... Like i said i know its probably not super important just cuz i only have 1000 watts on a pair of 12's .. Quote ** in with the new**96 grand am GT 2- dc lv 3 12'smemphis mc1000d145.3@46 hz** out with old**96 Grand am GT12w71000/1 143.6 @ 46 hz on the new TLhttp://img220.imageshack.us/my.php?image=av1023dc4.jpg
DRAMAQUEEN Posted April 28, 2008 Author Report Posted April 28, 2008 (edited) Rather then just using resin I would cut 45's out of mdf and then lay matt on top of that, it will save on resin. And allso if you mix your resin right it doesnt take too long to dry, mine normally is dry with in 2-4 hours depending on the weather. Also what is the correct way to mix that resin?? never used it, sorry for all the noob question s **edit** im sure theres lots of pics on here of the resin edges and the 45's mdf .. Anyone have any pics Edited April 28, 2008 by hzsogood Quote ** in with the new**96 grand am GT 2- dc lv 3 12'smemphis mc1000d145.3@46 hz** out with old**96 Grand am GT12w71000/1 143.6 @ 46 hz on the new TLhttp://img220.imageshack.us/my.php?image=av1023dc4.jpg
LSN2meBoom916 Posted April 28, 2008 Report Posted April 28, 2008 Rather then just using resin I would cut 45's out of mdf and then lay matt on top of that, it will save on resin. And allso if you mix your resin right it doesnt take too long to dry, mine normally is dry with in 2-4 hours depending on the weather. This is true...esp since the resin will generally CRACK as it cures esp if you mix it too "hot" (more hardener than neccessary) Also what is the correct way to mix that resin?? never used it, sorry for all the noob question s**edit** im sure theres lots of pics on here of the resin edges and the 45's mdf .. Anyone have any pics Read the label. With the Bondo brand resin I believe they say 12drops per 1oz resin..but you can mix it "hotter" (more hardener/ per resin ounce than that) depending on ambiant temp. A space heater will speed dry time if it's cold. Quote COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
DRAMAQUEEN Posted April 28, 2008 Author Report Posted April 28, 2008 thanks alot guys.. I gotta figure out what i want to do.. Im assuming there both going to have the exact same result so if i end up getting the subs early ill do the 45's otherwise ill try the resin.. And a half inch roundover Quote ** in with the new**96 grand am GT 2- dc lv 3 12'smemphis mc1000d145.3@46 hz** out with old**96 Grand am GT12w71000/1 143.6 @ 46 hz on the new TLhttp://img220.imageshack.us/my.php?image=av1023dc4.jpg
Torres Posted April 28, 2008 Report Posted April 28, 2008 heater or work lights if you can get em close enough. in 30 degrees yeah it'll take a long time, but in warmer weather it can take like a half hour to dry. Quote
DRAMAQUEEN Posted April 28, 2008 Author Report Posted April 28, 2008 heater or work lights if you can get em close enough. in 30 degrees yeah it'll take a long time, but in warmer weather it can take like a half hour to dry. yea ill try the resin.. im sure i wont mess it up tooo bad ha I gotta go grab some carpet and some black gloss paint, for my first attempt at that too lol.. This is going to be intteresting Quote ** in with the new**96 grand am GT 2- dc lv 3 12'smemphis mc1000d145.3@46 hz** out with old**96 Grand am GT12w71000/1 143.6 @ 46 hz on the new TLhttp://img220.imageshack.us/my.php?image=av1023dc4.jpg
DRAMAQUEEN Posted April 29, 2008 Author Report Posted April 29, 2008 2 more quick dumbass questions .. i know.. Before you lay down the resin is it necessary to run a bead of caulk around the entire perimeter then lay it down, or just brush the resin on? that make sense? And when doing 45 degree mdf corners what s the best way to get them tight ? glue then screw them in ? Quote ** in with the new**96 grand am GT 2- dc lv 3 12'smemphis mc1000d145.3@46 hz** out with old**96 Grand am GT12w71000/1 143.6 @ 46 hz on the new TLhttp://img220.imageshack.us/my.php?image=av1023dc4.jpg
Noobtastic14 Posted April 29, 2008 Report Posted April 29, 2008 the resin will seal it up- no caulk or silicone needed. and i always glue and screw my 45s just because of preference- is it required? idk but it doesn't hurt!! -Drew Quote I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew
DRAMAQUEEN Posted April 29, 2008 Author Report Posted April 29, 2008 the resin will seal it up- no caulk or silicone needed.and i always glue and screw my 45s just because of preference- is it required? idk but it doesn't hurt!! -Drew thanks man, you screw them from the inside ? As in having 2 screws up top and bottom angled to go to the back and side s of the box or screw thm in from the outside , and what width you think is best for the corners? 2-3 inches , then 45 both sides? Quote ** in with the new**96 grand am GT 2- dc lv 3 12'smemphis mc1000d145.3@46 hz** out with old**96 Grand am GT12w71000/1 143.6 @ 46 hz on the new TLhttp://img220.imageshack.us/my.php?image=av1023dc4.jpg
Dale Posted April 29, 2008 Report Posted April 29, 2008 with my 45s I just use wood glue and brads to keep it in place. Then caulk to seal it off nicely i don't think it will be necessary for you to use caulk before the resin since the resin will seal your corners for you anyway Quote
