How to make roof stout with out losing headliner in the process.
Have a 2000 mercury mountaineer (same as explorer) trying to deaden the roof. Already broke a roof support with my current system. 4 ab xfl 1222s on dc5k. Now wanting to make roof stout without losing headliner. First have to fix broken roof support then thinking of putting foam in them and other hollow areas. Then pl premium all the roof supports. And other potential weak points. Then doing 2-3 layers of second skin over the big areas. Was also thinking about gluing some birch to the roof between the supports to make it more solid. Please help first time deadening a roof and doing a build with 10k and don't want to keep breaking stuff. But don't want to loose headliner. Ty
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
i was able to kerf a sheet of 3/4" while fitting my headliner back on.
You mentioned that you have roof supports. I would start by putting wood in between each support as well, and go from there.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Should I deaden and do wood?
I would just do wood.
LMFAO so true
:blush:
I deadened at first not knowing I would need to do a wood roof.  I didnt remove the deadening when I added the foam and wood (out of laziness), and I dont think there was a benefit.  The roof is so solid with the wood addition that the deadener will be better suited elsewhere in the vehicle.
IG @walledsonic
  • Who's Online   1 Member, 0 Anonymous, 1202 Guests (See full list)
