Today, for the first time, I used my amm1 on a strapped pair of amps. Not that it matters, but the setup is 2 Sundown SCV 6000 strapped at 1 ohm. so each sees .5 nominal. I clamped 5800 watts through the positive side at .8.
Since the amps are STRAPPED, does that mean that i was clamping 5800 watts out of 1 amp or both amplifiers. and was it seeing .8 ohm per amp?
Please help lol
p.s. nice to be here again. been a while!
I would say that would be your total combined power because strapped amps work as a push / pull configuration or in series basically. So you would be able to measure anywhere in the circuit to get the power reading.
Pioneer 80PRS
Where did you have you + & - test leads attached to?
You are probably seeing combined power.
Builds:
I would put them on the wires going to the speakers for total power. If you had them on the same amp then you only got power for that amp -maybe.
Edited by ShadeTreeMechanic
Pioneer 80PRS
Brandon, Ive done some playing around. My American Bass 4ch is bridged on my mids.
When I hook up my DMM to just my front left channel, I get voltage a.
When I hook up my DMM to just my front right channel, I get voltage b.
When I hook up my DMM to where the speakers acutally are, I get voltage c.
Voltage a = voltage b
Voltage c is double voltage a, or double voltage b. (However you want to look at it).
Clamping speaker outputs still requires looking at acv, so I feel that you need to double the power you clamped with the AMM.
I know, bridging =/= strapping
Because of this, you could clamp your DC power run from either 6k to confirm. If youre drawing ~300 amperes per amplifier, then you are actually clamping around 5800 watts total. Whereas, if you are clamping ~600 amperes per amplifier, then you are getting 5800wrms/amplifier.
Sorry for rambling lol... but that should be expected <3
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Hah
Edited by DirtySouthWookie
hi
1997 Yukon / 2 Sundown SCV 6000D strapped @1 ohm / 3x 300a Ohio Generator Alts
4 Sundown X18s v.2 NS v.3 coils / B pillar wall sealed / 158.2@38Hz 156@25Hz
If you have the test leads wired to the inputs going to subs, that is going to tell you total power (both amps combined).
Builds:
  • 4 months later...
I know this is an old post, but I couldn't find anywhere else on the internet that had the answer.
On 4/25/2017 at 2:59 PM, strangeduck said:
maybe positive to master and negative to slave positive. someone will say for sure
^Strangeduck hit the nail on the head with his guess
When you AMM-1 strapped amps, you do it like normal. Run 1 wire through the machine, then put the clamps on both amp's positives (one amp should have the positive wires from the subs [master amp] and the other amp will have the negative wires from the subs [slave amp])
the AMM-1 will then measure impedance and power from both amps COMBINED.
source:
Two SQ2200s @ 1 ohm each
Juice box (34hz note the entire song) saw me rising to 5 ohms collectively (2.5 ish per amp) and clamped around 1500w
Edited by RedFred
  • Who's Online   0 Members, 0 Anonymous, 804 Guests (See full list)
