ShadeTreeMechanic Posted May 1, 2017 Report Posted May 1, 2017 31 minutes ago, d-nice88 said: You4 right ill change it up. Also to get that .67 ohm load i wired one sub all parallel and the other one series parallel to get .67 ohms Wow, no. That will not divide the power evenly between the two. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
d-nice88 Posted May 1, 2017 Author Report Posted May 1, 2017 One sub will be getting more power then the rest ?
ShadeTreeMechanic Posted May 1, 2017 Report Posted May 1, 2017 Yes. In order to have the power divide evenly, you have to wire each sub the same way. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
WalledSonic Posted May 1, 2017 Report Posted May 1, 2017 I think OP is mistaken bc running a sub in parallel, a sub in series, and then parallel between them would cause the amp to see: D2 = 0.8ohm D1.4 = 0.56ohm and of course D1 & D0.7 each end up lower than 0.56ohm so no need to calculate. Anyway, I hope D gets it all wired up proper. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
d-nice88 Posted May 2, 2017 Author Report Posted May 2, 2017 Yea im just gona run it at half ohm then with 2 dual 2 ohm versions of the zvx
d-nice88 Posted May 5, 2017 Author Report Posted May 5, 2017 Any one know what the sq of port area and the cubes of the driver ported of the ampere audio v2 18?
