Check my box specs please.
d-nice88
Just wanted to kno if this will be good for the Skar audio zvx 18's v2. It is going in a 95 gmc pick up in the ext cab. Going to be subs forward and port up. Being powered by 3 xs power d3400 mechman 270 alt. 0 gauge wire. Wire from batt to sub amp will be 2/0 gauge. (maybe get dual inputs) Amp is an audio legion 3.5k and it will be wired down to .67 ohms. Will the box specs work for those 2 18"s?
How are you going to wire two subs to .67 ohms?
Builds:
2 hours ago, d-nice88 said:
I did it once. Idk how i did but i wired them up to .67 ohms my old bl 15's i got them down to .67ohms
There is something not right about that, but whatever.
As far as your box specs go, I think everything looks good.
Builds:
Fi build house is 2, 1.4, 1, or .7
You would need 3 D1's to get .67
7 minutes ago, d-nice88 said:
You4 right ill change it up. Also to get that .67 ohm load i wired one sub all parallel and the other one series parallel to get .67 ohms
So you wired one sub parallel to itself, then the other series to itself, then the two subs parallel to each other?
IG @walledsonic
  • Who's Online   0 Members, 0 Anonymous, 1434 Guests (See full list)
