Kyblack76 Posted December 11, 2017 Report Posted December 11, 2017 Very nice man. The reconing sucks, but, ... build looks great. Just curious, how you meter? Out law? Legal? Or ? Looking great man. You do some nice work. Keep on er... good luck. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
WalledSonic Posted December 11, 2017 Report Posted December 11, 2017 Surprised you were only rising 2X. Also, that DD should take 1/2 ohm no problem. Either way, it looks good man, keep at it! Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
loud360durango Posted December 11, 2017 Author Report Posted December 11, 2017 54 minutes ago, Kyblack76 said: Very nice man. The reconing sucks, but, ... build looks great. Just curious, how you meter? Out law? Legal? Or ? Looking great man. You do some nice work. Keep on er... good luck. It was a 157.2@30hz with drivers door open on dash and a 157.5@55hz sealed on dash. Weird I know lol
loud360durango Posted December 11, 2017 Author Report Posted December 11, 2017 1 minute ago, WalledSonic said: Surprised you were only rising 2X. Also, that DD should take 1/2 ohm no problem. Either way, it looks good man, keep at it! Yeah it would protect as soon as I turned it up every time. Wired to 1ohm and worked perfectly
loud360durango Posted January 29, 2018 Author Report Posted January 29, 2018 Small update Sold some of the V2 to get try to get all V1. Worked on the battery rack and amp rack. Trying to play around with ideas and I like the approach its going now. Basically the amps will be screwed into a piece of wood that is jigsaw out that you only barely see any wood expect where the screws will mount. Then that same piece of wood is kreg jig into a bottom piece. 3 amps on top and 3 amps on the bottom. I will be running them strapped each pair @ 1ohm(.5 per amp). I am still trying to figure out to do with the middle piece though. I am ordering a custom light from low notes garage and I want it to go between the amps so I will figure out something soon for them. The link bars should be here soon as I can get started on wiring very soon and ordered a cockbox. Anyways enough babbling lol
loud360durango Posted February 2, 2018 Author Report Posted February 2, 2018 Got 6 in for looks purpose I did order my custom glass piece from Brent Leavitt. I did decide to cut the middle boards between the amps back to the same width as the bottom piece but leave a gap in the middle that will stick out for the glass piece to mount on...hard to explain but will look like this Waiting on the link bars but will start measuring out he holes that will go for the amp inputs this weekend hopefully
loud360durango Posted March 13, 2018 Author Report Posted March 13, 2018 Few updates First I didn't like the way I had the amp/battery racks sides and it was driving me nuts so I tore it out and came up with this design Still going with the floating amps look Amps just waiting on me lol
loud360durango Posted March 13, 2018 Author Report Posted March 13, 2018 Ended up hiding 2 batteries under the box in the back and one on the passenger side rear Started fiberglassing and ran wires
loud360durango Posted March 13, 2018 Author Report Posted March 13, 2018 Painting just the main areas I still have to seal off the passenger side with fiberglass but that will be done the road after I do some testing because I still need access to the wires Finally wiring up amps 3 left to do right now
