Joey5395 Posted May 15, 2017 Report Posted May 15, 2017 My brother recently had an amplifier and subwoofer installed in his 2010 bmw 328 with the base factory radio with no factory amp. I tried adjusting the settings on the amplifier but the sub still sounds horrible. I decided to take the sub out and swap in mine, his subwoofer in my car sounded great but my subwoofer sounded like shit in his. What i am wondering is can high level inputs cause this problem or could it be because of the shop who installed it? MY brother's sub and amp were installed by a local "professional" shop and my backyard install on my 2009 bmw 335 with a loc puts it to shame.
06RTCharger Posted May 15, 2017 Report Posted May 15, 2017 If theres lots of vocals and highs and no bass coming out of a sub, id think that meant the crossover points were messed up. Check what the amps crossover is at.
Quiet Posted May 15, 2017 Report Posted May 15, 2017 Sounds like your LPF is off. Make sure it's on and set it to 80hz for starters, then adjust as necessary. 2007 Pacifica Rebuild. Less quiet. Still not loud.
Joey5395 Posted May 15, 2017 Author Report Posted May 15, 2017 49 minutes ago, 06RTCharger said: If theres lots of vocals and highs and no bass coming out of a sub, id think that meant the crossover points were messed up. Check what the amps crossover is at. 31 minutes ago, srp365 said: Sounds like your LPF is off. Make sure it's on and set it to 80hz for starters, then adjust as necessary. I turned the high pass filter all the way down, turned the low pass on it had more base but the vocal were still there. I figured from personal experiences on both of my cars that it was the high pass filter that was messed up but i couldn't get the vocals to go away.
Quiet Posted May 15, 2017 Report Posted May 15, 2017 You are gonna hear some vocals unless your LPF has a steep slope, which it likely doesn't. HPF. should be off. 2007 Pacifica Rebuild. Less quiet. Still not loud.
slowfkncar Posted May 15, 2017 Report Posted May 15, 2017 Vocals but no bass? If you look in your trunk on the left side you have a small plastic panel laying horizontally, Pop it off to double check that you don't actually have a factory amp, if not then where did they tap the speaker wires?
Joey5395 Posted May 15, 2017 Author Report Posted May 15, 2017 Yeah I checked his car doesn't have an factory amp, and I couldn't find where they tapped the wires into.
slowfkncar Posted May 16, 2017 Report Posted May 16, 2017 4 hours ago, Joey5395 said: Yeah I checked his car doesn't have an factory amp, and I couldn't find where they tapped the wires into. If you drop the lpf all the way does it still sound like shit? If so just take it back and have them look at it, if its non-amplified then the signal shouldn't be too bad since its full range. If you decide to do a little troubleshooting yourself then this may help. 12V Radio Ground Radio Ignition Radio Illumination Factory Amp Turn-on Power Antenna Left Front Speaker (+/-) Right Front Speaker (+/-) Left Rear Speaker (+/-) Right Rear Speaker (+/-) Center Channel (+/-) Subwoofer (+/-) Aux. Audio Input Left (+/-) Aux. Audio Input Right (+/-) Satellite Radio 12 Volts Satellite Radio Ground Satellite Radio Ignition Satellite Radio Antenna Satellite Audio Left (+/-) Satellite Audio Right (+/-) Wire Color red/green brown (CAN BUS) gray/red (dimmer) same as power antenna (HiFi); (MOST BUS, Top HiFi) black or white/purple blue/white - blue/brown or yellow/red - brown/org blue/black - blue/brown or blue/red - brown/orange yellow/red - yellow/brown or yellow/blk - brn/org blue/green - blue/brown or blue/black - brown/org black/white - black/brown red/wht - brown/yel (L); red/blue - brown/wht (R) white - (shield) or black - (shield) gray - (shield) or yellow - (shield) red/blue brown (MOST BUS) (coaxial cable) (MOST BUS) (MOST BUS) Polarity + - + + +,- +,- +,- +,- +,- +,- +,- +,- + - Wire Location radio, 16 pin plug, pin 15 radio, 16 pin plug, pin 12 radio, 16 pin plug, pin 14 radio, 16 pin plug, pin 13 radio, 16 pin plug, pins 3 - 7 radio, 16 pin plug, pins 2 - 6 radio, 16 pin plug, pins 4 - 8 radio, 16 pin plug, pins 1 - 5 amplifier in left side of trunk, 20 pin plug, pins 5 - 15 amplifier, 42 pin plg, pins 4-3; 23-22, or 20 pin plug, pins 8-18; 6-16 radio, 12 pin plug, pins 2 - 8 radio, 12 pin plug, pins 7 - 8 Sat Radio under trunk floor, 3 pin plug, pin 1 Sat Radio under trunk floor, 3 pin plug, pin 3
Joey5395 Posted May 16, 2017 Author Report Posted May 16, 2017 I just realized the guys who installed it wrapped the power, ground and input wires together, could that cause the problem?
reedal Posted May 16, 2017 Report Posted May 16, 2017 No. That will not cause your issue. The signal for the amp is likely tapped into a source that is filtering out the lower notes. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
