ShadeTreeMechanic Posted June 17, 2017 Report Posted June 17, 2017 Maybe it's a new hybrid. Two channel mono. Lol 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Kyblack76 Posted June 17, 2017 Report Posted June 17, 2017 1 hour ago, ShadeTreeMechanic said: Maybe it's a new hybrid. Two channel mono. Lol Sounds like my ex-wife. Single but had 3 relationships. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
boomintahoe Posted June 18, 2017 Report Posted June 18, 2017 13 hours ago, slowfkncar said: I think your mislead, two pairs of terminals is not the same thing as two outputs. One can be bridged, the other cant. Also, his installer didnt remove the woofers from the enclosure because there was absolutely no need to, everything needs to stay paralell in that situation. You need to go back and re read my reply again, as for the wiring for subs. Don't know why there's arguement here. A lot of amps that are mono are split into for what appears to be a "2 ch amp".
ShadeTreeMechanic Posted June 18, 2017 Report Posted June 18, 2017 5 hours ago, boomintahoe said: You need to go back and re read my reply again, as for the wiring for subs. Don't know why there's arguement here. A lot of amps that are mono are split into for what appears to be a "2 ch amp". We are just trying to bring you back from left field. If a mono amp had two channels, then it would be a two channel amp. These guys have brought me back from left field a few times too. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
06RTCharger Posted June 19, 2017 Report Posted June 19, 2017 16 hours ago, ShadeTreeMechanic said: We are just trying to bring you back from left field. If a mono amp had two channels, then it would be a two channel amp. These guys have brought me back from left field a few times too. Would an example of hes talking about be like the linear power amps? How some of their mono amps have 4 speaker wire terminals. Those kinna tripped me out when i was looking at pictures of the 8002SW, i still dont know what its for but i know its not a two channel lol.
ShadeTreeMechanic Posted June 19, 2017 Report Posted June 19, 2017 A lot of mono amps have multiple terminals to make wiring multiple subs easier. Linear power made in America. Good to see something is still made here. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
