Triticum's Improved Port Area Calculator
5 hours ago, CrackFactory said:
Is it just a visual update or have any formulas changed?
Just visual.  All the formulas should be the same.
Builds:
  • 2 months later...
Super calculator, will it work for a 7 cubes box tuned to 30hz on 6k? Gonna be running a fi delta and I saw that someone had an issue with power density of 500w per cube and I'm at almost 900. Thank you.
Im sorry to revive this old thread but i must ask: ive been using your calculator and built several enclosures with it. I dont have tools or expertise to build the actual boxes myself, so i source out builders and they often question me why im using such a big port. I tell em to do it anyways. Now then, i did notice a couple times my bandwidth seemed small. So my question is: How does using these bigger than manu recommended ports/port area figures alter or affect the bandwidth? It seems to me the larger ports cause a narrower bandwidth in exchange of .5dbs output gain over a narrower bandwidth. Is this whats going on?
  • 4 weeks later...
ive experienced this too. im curious to see what the answer to this is.
  • 3 months later...
Larger ports don't make for a smaller bandwidth.  This is an car audio urban legend that has been around forever but just refuses to die.
If a port is too small, you will lose output around the tuning frequency, when playing at high volumes.  This will make it SEEM like you are getting wider bandwidth, but it comes at a horrible cost.  For one thing, it will only work when playing at high volume when there is a lot of port velocity.  At lower volume levels your bandwidth will be exactly the same regardless of port size.  The other problem is, making your port smaller to try an tame an output peak is like making the exhaust on your car purposefully small to keep from breaking the tires loose in 1st gear.  Its just a stupid way to solve the problem and it impedes performance the whole rest of the time.
Builds:
Omg... if you're trying to size a port with higher power... modeling can give you useful info,
A calc is a shot in the dark imo... extreme power with a set excursion usually
A calc is only useful with lower power situations... add 30mm of xmax and 2K clamped /w/ filters and that calc gets beat pretty fast.
This thread should encourage noobs to learn modeling.. NOT rely on a calc.. power is cheap and most are looking for hi-power solutions.
I agree.  I made the calc to help people who don't have access to better tools, like real modeling software.  The calc also isn't meant to be a completely replacement for knowledge and experience.
Builds:
  • 4 weeks later...
On 7/7/2020 at 9:11 AM, Dexterity said:
I’m a little late to the party but the calculator is broken again. When I try to enter the tuning frequency it wont allow me to because it’s been set to view only.
Should be fixed, shoot me a PM if it isn't.
Builds:
  • 1 month later...
Whats the secret to implementing the given amount of port area and area/ft^3 while sticking to your net cubic feet? I am using the Torres calculator and cannot do it.
  • Who's Online   0 Members, 0 Anonymous, 1817 Guests (See full list)
