I have a pair of DD M2C’s at .5 I am upgrading my stock battery from a deep cycle lead acid to something else.  I will have a pair of 300a alts .  My question is , I have been pondering the idea of 10 kinetic hc600-rev or 4 xs power 1800’s and last but not least a pair of NSB 480’s .
Would there be a benifit to all the small batteries over less larger ones?
With the amps I have would these be over kill or am I on point?
thanks in advance
A lot of people will run 100ah per 1000 watts. The only reason to run more smaller batteries would be to better fit the install. There really wouldn't be any benefit if you can fit big batteries. More smaller batteries need more connections. More connections mean a higher chance of a connection failing or going bad.
Pioneer 80PRS
Would a pair of NSB 400’s be enough for my setup or would I need the 480’s?
thabks for the info on the multiple batts I think I will stick with simplistic just need to figure out how many budget is kinda tight, also open to suggestions on batteries for the setup. Thanks again
If you can afford the 480's $ and the weight, go for it. NS is get stuff. GP has a sale going on for the 4th of July.
http://gpcaraudio.com/bundle-2-northstar-smsagm480-w-gp52-terminals-noco-g26000-charger/
  • Who's Online   1 Member, 0 Anonymous, 1175 Guests (See full list)
