Box design for 2 Kicker CVX 12s
treyS3469
Okay so I bought 2 Brand new Kicker CVX 12s for a great deal from a local shop and I need help with a box either a ported box I need someone that can help me they will be powered by an alpine 1200 amp at 2 ohms it will be going in a 2017 Ford Fusion Space isn't an issue I mostly listen to Rap so I want it to be loud I appreciate the input.
Should probably post up ur MAX dimensions u have available in the trunk. Just so that the person thats going to help u doesnt waste their time designing a box for u and then u come back and say the box cant fit. Use a tape measure and get the height, width and depth you have in ur car.
Okay so I when to the store and bought a tape measure and my dimensions are
height: 17.5"
width: 39"
depth is 20"
and I bought a sheet of .75" MDF while I was there along with some brad nails, tite bond wood glue and some silicone.
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/4" , figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Okay so it took me sometime out of my schedule to make the dummy box and it did fit perfectly no problems I just need to build the box now and I will probably come back let you guys know how it sounds and again thanks Joe X for the blueprints I appreciate the help
  • Who's Online   0 Members, 0 Anonymous, 6453 Guests (See full list)
