DC Sound Lab
 I have 3 orion HCCA 152 woofers that im running on some off brand 3500 watt amps.  I wanna go with one solid amp to run all 3 at a 1.33 ohm. this is a daily driver 2003 trailblazer but I want it to hump.  the woofer are rated at 2500rms/5000peak, I currently have 5 d3100's in the back, 1 redtop in the front that I want to change out but need to find a battery that will fit due to the dual alt bracket that holds a 240 mechman and a 370 mechman.  out of these 3 amps, which one would you recommend I run on those 3 woofers with my current setup.  thanks for any assistance you can give me.
  • hayabusaboi06 changed the title to need a new amp: 7.5k, 9k or 10k
7500Wrms is what you need at 1ohm, so I would go with a 10K at 1.33ohm.  Even then, you may not even be pulling RMS wattage.  The idea is to oversize your amp so that you dont push it into clipping.  Thats my opinion, anyway.
IG @walledsonic
Definitely better to stick with shorter boards... Cheaper when one shits the bed.  Plus, its harder to get rid of a large board versus a few smaller ones.
IG @walledsonic
