2002 Subaru Outback slow build
Photobucket took a shit and I lost my original  build log. Aftet speaking with another member here, I decided to give it another shot. Sooo deaden first
Lots of sheet metal too hush-up
PL and foam to do the dirty work
Must make it squeekey clean first thoe
As per SnowDrifter's advice, I PL'd all seams between sheet metal and bracing
And foamed every orifice I could get access to
Now on with the deadening! Secondskin ftw. B stock too
More to come tomorrow...electrical. Thanks for watching
On with the electrical: 2 runs of Sundown 1/0 front to back, 2 runs of GP 2/0 charging wire (scraps I found laying around), Mechman 1/0 for the big 4 and multiple chassis grounds.
Had just enough Sundown for the two runs.
Went through the floor behind the driver seat. To many pinch points and twist and turns beyond that point.  Used a grommet and PL to secure it.
On with the rear grounds. Everything copper lugs, crimped and adhesive heat shrink. Painted and dielectric too
Rear bumper had to be removed in order to accomplish the next task, so why not seal off the vents. Controversial, I know
Now here's where the tricky part came into play. Note the right angle drill that didn't fit. After making a few "adjustments", it worked
After a little PL and some massaging, all is well. Drilled a few pass throughs, stainless, lock washers, painted and dielectric
There was a riged fome Storage Tray underneath the false floor that I cut to accommodate the grounds
Added a few more grounds upfront
AGM 24 upfront, 3100 in the rear, maby a little lithium in the future. Stock alt, US 280a still being built. DC5K on the shelf. AB 1880.1 powering a single 15 in a parallel 6th  (much thanks to Triticum and JoeX), stock fronts on deck power for now. Doors are next. I'll post the doors tomorrow. Evil6.5's maby?
Thanks for taking lots of pics. and doing the sound deadener first, lol!  Serious about that shit with taking the bumper off.  =O  Running those grounds looks so clean dude great work!  Those Evils are good mids, not a bad choice if you do go that route.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Awww yisss.  Tuned in!  I wish they made those SSA6.5s in an 8".
IG @walledsonic
Thanks gents! On with the doors: panel came off easy  but the vapor barrier tooka little effort. Wanted to save it
Everything cleaned. Used the vapor barrier as a template. Hole saw and hammer for access to body clips
For the door lock/ opening mechanism I used heavy-duty disposable shop towels to protect. Then adhered the SecondSkin.
So after removing the factory door speakers,  found that the OEM speaker adapter is angled at 22 degrees (or so) toward the driver seat. Thank goodness cuz I thought I might have take more time fabing. The OEM adapter wouldn't fit the Evil at first but with a little sanding, it worked.
Doubled up the Sundown 16awg through the boot and behind the dash to the passenger side, that was a pain. RCA's on the same side too
Got some SecondSkin speaker tweeters also. The impact bracing in the door complicated things but I think I made it work
Nice packaging and a little perverted. She'll get get the job done
Hell yeah git that sh*t
IG @walledsonic
  • 4 weeks later...
