Nightmare9400 Posted October 5, 2017 Report Posted October 5, 2017 Looking for a battery tender, I don't always drive my audio vehicle and want to keep the kinetiks 100% an a steady voltage. Recommendations and suggestions thanks ?
8ten8 Posted October 5, 2017 Report Posted October 5, 2017 I like NOCO. This is the 120ah version. There are more ah versions available https://www.amazon.com/NOCO-G3500-UltraSafe-Battery-Charger/dp/B004LWVEKS#
Nightmare9400 Posted October 5, 2017 Author Report Posted October 5, 2017 What type of batteries do you run using that NOCO battery charger/tender on?
Karkov Posted October 5, 2017 Report Posted October 5, 2017 I as well used to have a NOCO but the 7.2a version, I had to order it online, the 3.5 you can sometimes find in stores. It's very similar to CTEK I now use this one and love it https://www.griotsgarage.com/product/microprocessor-controlled+battery+charger-maintainer.do 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
Mitchaford Posted October 5, 2017 Report Posted October 5, 2017 21 hours ago, 8ten8 said: I like NOCO. This is the 120ah version. There are more ah versions available https://www.amazon.com/NOCO-G3500-UltraSafe-Battery-Charger/dp/B004LWVEKS# That is what i use. love that thing. 2008 VW Jetta Team Fi 12 CT 4000.1 CT 125.4 PWX 6.5 80 PRS EB Flex 2/0 Second Skin ^^^ Build ^^^
audiofanaticz Posted October 6, 2017 Report Posted October 6, 2017 How big is your battery bank (what model kenitiks and how many)?. I have a noco 3.5 amp on two Stinger SPV70 batteries in my garage, and that thing is charging non stop. Way too small for those 2 batteries. I would recommend buying a slightly larger charger than needed just in case you ever decided to compete and want to get a full charge between runs. In my truck I run a big red XS Power charger, but want to swap it out for one of their new 60amp intelichargers.
Nightmare9400 Posted October 6, 2017 Author Report Posted October 6, 2017 I have (2) kinetik blu2000s right now but will be adding a 3rd. I'm looking at the Ctek7002 and the Noco 7200 for chargers.
Nightmare9400 Posted October 6, 2017 Author Report Posted October 6, 2017 9 minutes ago, audiofanaticz said: How big is your battery bank (what model kenitiks and how many)?. I have a noco 3.5 amp on two Stinger SPV70 batteries in my garage, and that thing is charging non stop. Way too small for those 2 batteries. I would recommend buying a slightly larger charger than needed just in case you ever decided to compete and want to get a full charge between runs. In my truck I run a big red XS Power charger, but want to swap it out for one of their new 60amp intelichargers. I have (2) kinetik blu2000s right now but will be adding a 3rd I'm looking at the Ctek7002 and the Noco7200 for chargers.
audiofanaticz Posted October 6, 2017 Report Posted October 6, 2017 Either of those chargers will for your current 2 batteries now. If you add a 3rd kinetik you may want to look at the next model up for the Noco because your looking at 270ah worth of batteries and 230ah worth of charging. Batteries would take a while to charge at 2.3 amps of current per battery ( I try to give mine between 5-10 amps of charger per battery). That CTEK 7002 is a tad smaller amperage output wise than the Noco G7200. Plus Im willing to bet you have a starting battery in the vehicle which is wired in parallel with your current to Kinetik so you would have 3 batteries currently (4 if you buy a 3rd Kinetik), even if 1 is a different brand battery it would still add to the total of batteries needing to be charged. So ideally you would want to be looking at the 15amp Noco G15000. Your call though. The others would work, but it would just take a really long time to charge.
Nightmare9400 Posted October 6, 2017 Author Report Posted October 6, 2017 15 minutes ago, audiofanaticz said: Either of those chargers will for your current 2 batteries now. If you add a 3rd kinetik you may want to look at the next model up for the Noco because your looking at 270ah worth of batteries and 230ah worth of charging. Batteries would take a while to charge at 2.3 amps of current per battery ( I try to give mine between 5-10 amps of charger per battery). That CTEK 7002 is a tad smaller amperage output wise than the Noco G7200. Plus Im willing to bet you have a starting battery in the vehicle which is wired in parallel with your current to Kinetik so you would have 3 batteries currently (4 if you buy a 3rd Kinetik), even if 1 is a different brand battery it would still add to the total of batteries needing to be charged. So ideally you would want to be looking at the 15amp Noco G15000. Your call though. The others would work, but it would just take a really long time to charge. I agree 100% with you, definitely have a good point on ah and slow charging time. I actually don't have a starting battery, 1 of those kinetiks is under the Hood, my mistake. So my (battery bank) will be (2) kinetik blu2000s and under the Hood(starting battery is also kinetik blu2000. Now the Noco G15000 conditions also correct, I'd want to be able to park my suv an connect the noco an not have to worry an keep them charged an maintain steady voltage. What charger/maintainer do you run with what of battery bank total.
