Question : dual 12 sealed box. 1 vs 2 chambers ?
Dragonware
Question is as simple as the title pros and cons ?
Also if answer is 1 chamber do they need to be equally spaced?
12 inch RE Audio  SEX reconned with psi drop in kits. Dual 1 ohm capable of up to 1500 rms .
Powered by hifonics brz 2000.1d
My Build log :
http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/
Current System
2020 Ford F-150 XLT Supercrew
Audio Control Epicenter
Audio Control LC7i
Taramp PRO 2.6 DSP
Taramp DS4x800 - Highs
Taramp HD3000.1  Mids
Taramp MD5000.1 Bass
8 x DS18 6.5 Pro x6m - mids
2 x Soundsteam SST-05 Bullet Tweeter
2 x DS18 TW220 Super Tweeters
4 X SkarAudio EVL-8  BASS
Big 3
Yellow Top
I’m running 3-10’s , 1 box with 3 chambers was told by Sundown that was the best way for my subs. I would differently do 2 chambers .
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
Thanks any one else have thoughts on this also ?
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
I would do one chamber. Saves space. I don't see a reason that two separate chambers would be better.
Yup, I vote for a single chamber as well.  The only advantage to having separate chambers is if you blow a sub the remaining subs won't suddening be performing like they are in a larger enclosure.  That shouldn't be much of a concern though.
Builds:
since i re conned them from the original 650 RMS   that blew every 2 months ..for the past 3 years I have been beating them daily with 2000 RMS  and they are solid.
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
  • Who's Online   1 Member, 0 Anonymous, 1626 Guests (See full list)
