Mitchaford Posted February 6, 2018 Report Posted February 6, 2018 Does anyone have/use threaded inserts with the SMD big red self tappers? I can order online I’m sure but if they are at Home Depot/ Lowe’s then even better. Ive been swapping subs with the same box. I don’t want the holes to get too get too worn down. Probbaly should have done this in the first place. 2008 VW Jetta Team Fi 12 CT 4000.1 CT 125.4 PWX 6.5 80 PRS EB Flex 2/0 Second Skin ^^^ Build ^^^
audiofanaticz Posted February 7, 2018 Report Posted February 7, 2018 Those self tappers are not for threaded inserts its a huge coarse thread. If you want to use threaded inserts you need bolts not self tapping screws.
WalledSonic Posted February 7, 2018 Report Posted February 7, 2018 M6 threaded inserts and M6 bolts may work well. Amazon. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
Mitchaford Posted February 7, 2018 Author Report Posted February 7, 2018 1 hour ago, audiofanaticz said: Those self tappers are not for threaded inserts its a huge coarse thread. If you want to use threaded inserts you need bolts not self tapping screws. 1 hour ago, WalledSonic said: M6 threaded inserts and M6 bolts may work well. Amazon. Ok thanks guys! Just want to make sure everything is tight and fastened down. Sub has a bit of weight on it, can’t take a risk ? 2008 VW Jetta Team Fi 12 CT 4000.1 CT 125.4 PWX 6.5 80 PRS EB Flex 2/0 Second Skin ^^^ Build ^^^
