Wishuponasub Posted February 23, 2018 Report Posted February 23, 2018 Alright so I'm finally getting around to installing my gear I have accumulated and need to start planning for box and amp placement. I will be running 4 FI X 10s on an Ampere Audio 3800.1 at 1 ohm. I hate just saying design this for me but I really am clueless here and would appreciate the help. Features X10 DUAL 2 | DUAL 4 Fs: 32.5 Hz | 32.5 Hz Re: 1.4 Ohms/coil | 2.8 Ohms/coil Qms: 6.01 | 6.01 Qes: .48 | .48 Qts: .44 | .44 Mms: 162g | 162g Cms: 0.00mm/N | 0.00mm/N Sd: 310cm^2 | 310cm^2 Vas: 19.66 l | 19.66 l Spl: 83.3dB 1W/1m | 83.3dB 1W/1m Bl: 14.01 N/A | 19.81 N/A Xmax: 20mm Rms: 750W Sealed box: .2-.4 cuft Ported box: .6-1.2 cuft @ 33Hz Sub OD: 11.000” Cut ID: 9.250” Mounting depth: 6.000” Displacement: 0.07cuft X Series: 10”, 12”, and 15″ Dual 2 and Dual 4 Ohm Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals Extra heavy lead wire FEA optimized motor 3” diameter 4 layer coil Single high grade magnet Triple progressive spiders Optional BP Cooling Sorry for the light text. The dimensions I came up with are 19"heigth, 37"width, 26" depth. That is the entire cargo area up to the seatline. That is all the way against the hatch too not leaving room for the port. So that would have to be taken into account. I would love for it to be 19"tall so I could look back and see them but it's not a must. Thank you advance for any help I receive. edit: I have the D2 if that makes much of a difference. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4
Wishuponasub Posted February 23, 2018 Author Report Posted February 23, 2018 I guess I left a few details out. I would definitely prefer ported. I mostly listen to rock/metal but when I really wanna get my bass fix I listen to rap. This setup will get metered but it's not to compete with. I just want a musical daily pounder. Edit: Damn so many details lol. It's going in a dodge caliber so subs up port back unless for some reason you think there is a better orientation. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4
ChevyBoy95 Posted February 23, 2018 Report Posted February 23, 2018 @Joe X Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Wishuponasub Posted February 27, 2018 Author Report Posted February 27, 2018 I employed someone locally to design and build me a box. Well most likely. We are ironing out the details Friday. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4
WalledSonic Posted February 27, 2018 Report Posted February 27, 2018 Post the design details back here before building, if you dont mind. Some of the pros might happen to be online by then and can help with confirmation of the critical values. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
Wishuponasub Posted February 27, 2018 Author Report Posted February 27, 2018 I'll see if he can send them to me. He "says" he's going to tune to 32 but he was researching the subs and how the caliber acts before making the final design. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4
WalledSonic Posted March 27, 2018 Report Posted March 27, 2018 Bump for interest/info Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
