okay on my head unit it has sw-phase you can set normal or reverse what does it mean reverse im lost :-[
Subs- 2AA Arsenal 15sAmps- Orion2500d/MemphisDoors- Infinity kapa/AA polymids(soon)Deck- Pioneer PrimerBox- 3.5 per chamber!!!!!!!!/28hzElectrical- two optima red tops/160alt(big 3 soon)OHIO BABY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i thought phase had to do with pos neg inputs rather then inverted or not.
from what ive read, it does. when you sync both amps on one sub, you can select 180 degrees on the amp with the negative. on the head unit, if you feel a delay in bass, you select that and somehow itll compensate i believe.
You guys are pretty much there!
Phase IS talking about how the subs (or any speaker for that matter) is/are wired.
Why it's important-
1: when you want your mids to play together (and thus louder) they should both be pushing in and out at the same time on bass notes even if it's midbass/midrange Hz.
Also-for the correct "stage" or "imaging" like if you have a track that fades left to right or front to rear etc. If your mids are out of phase (one wired +pos to +pos from amp and -neg to -neg from amp, and the other flipped +pos to neg from amp and -neg to +pos from amp) they will be working AGAINST each other, not only sound funny but be less loud.
2: Same goes for subs-especially imortant since we all need face smashing bass or as much as we can get-phase is important.
An out of phase sub will work AGAINST a sub wired in phase they will be "180 degrees" out of phase (exact opposites) and likely cancellation will occur=bad.
THIS happens a lot in setups where more than one sub is used and only one or SOME of the subs are inverted because one sub is pushing forward (cone out of basket and away from box), while another INVERTED is pushing forward (cone out of basket INTO box) and instead of compressing the air in the box it's actually just equallizing it -one woofer cone pushed in (-1) and one pushed out (+1)..-1+1=0..zero bass is no fun (this is assuming it's common airspace not divided for each woofer).
I've never had any issues since i either run all inverted or all standard mounting, and I'd venture to say as long as you wire it reversed for an inverted sub along w/ your regularly wired standard mounted subs OR VICE VERSA you shouldn't need to use the phase button...So really i dont know why that button is there unless its for lazy bastards who dont wanna re-wire anything after they screw up the pos/neg on a set of spealers/subs...and ALL the signal would be effected by one deck button so i dont understand for sure what good that would do either...unless it were subs in relation to mids being out of phase and you needed to sync the 2 systems?
Thats as much of an explaination as I can give right now since I should eb awirting a damn midterm paper... if I'm wrong on any of that I'm sure some O.G. member will flame me down into my rightfull noob place and correct it.
~My 2 cents hope that helped.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
im so lost so me putting my phase on reverse is saying my subs are inverted. they do sound different on reverse but my subs are mounted normally
  • Who's Online   0 Members, 0 Anonymous, 994 Guests (See full list)
