robsimon799 Posted April 30, 2018 Report Posted April 30, 2018 Bmw e46 m3 turbo coupe This is a list of parts I would like to have on the E46 And I want black interior and black car blue accents. I want AN fittings on everything under the hood even coolant hoses with AN fitting. Engine Debore sleeves CP Alum con-rods CP pistons 10.0:1 cr Oversize wrist pins 3.5L Stroker crank Custom FIC low Z fuel injectors VAC Custom made top mount turbo manifold PTE PT7675 CEA ported H cover Turbocharger ball bearing center ½” head studs if you can VANOS Elimination Kit Schrick cams highest DRA. Stage 3 porting head Super tech SS and inconel valves 1mm oversize Super tech Dual valves springs and all super tech valve train Pro EFI pro128 EMS Pro EFI Display Okada ign coils M&W Pro Drag 6 6ch CDI Bore throttle bodies and tapped for 4 stage NX nitrous 2 Electric cooling fans and alum rad VAC custom 4” inlet intake manifold Custom 3” inlet 4” outlet intercooler Custom 4” down pipe, vibrant cat, 2 4” vibrant racing mufflers to 4 tips Tial waste gates Tial blow off valves Body Asuka body kit, hood and trunk lid Sups Wheels and Brakes Blue K Sport 8 pod cails front and rear big brakes kits 19”x 13” rear, 19”x 10” front VIP Moduler VR06 chrome rims Nitto tires JRZ coilovers Tubular subframes front and rear with unibody weld ins. Tubular control and trailing arms front rear Custom front spindles custom rear knuckles Tilton 4 disk Clutch samsonas sin 6 speed Revshift flex disc Chromalloy custom driveshaft and CVs OS diff and 4.10:1 gears fuel Radium surge tank in fuel cell with methanol pumps. flexfuel CELL: 22 gal 4 Walbro F90000274 E85 pumps -10 fuel feed lines Radium fuel rail NITROUS 4 Cold Fusion 20 pound bottles 12 NX double stage SX2 Nozzles 4 NX PRO POWER LIGHTNING ALCOHOL SOLENOID WITH .310 ORIFICE 4 NX Lightning 375 NX purge to the NX cooler on the intercooler Nitrous fuel rails for cleaner install Audio Car pc with 7” screen and 10” screen Alpine DSP PXA-H800 and RUX-C800 2 Sets Morel Audio ELATE TI 903 1 Set ELATE TI 503 2 Rockford Power T600-2 1 Rockford Power T400-2 1 Ground Zero GZCA 35K-SPL 2 Ground Zero Plutonium GZPW 18SPL-EXTREME 4 xs power XS30K batteries windows tinted Corbeau CR1 heated seats L20901: Black Leather BMW RACING steering wheel Dual HID Blue lens projector full color Halo Full Black housing head lights LED black housing front side markers LED tail lights XK lighting under and inner I would like to cut the rear seats out and back deck with custom roll cage combatable for my wheel chair so I can fit two 18” subs and 4 batteries and 3 amps in the e46 i have some pics of that the body will look like Quote Edit
Broke_Audio_Addict Posted April 30, 2018 Report Posted April 30, 2018 Didnt we already establish that this is not your car? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
robsimon799 Posted May 1, 2018 Author Report Posted May 1, 2018 18 hours ago, Broke_Audio_Addict said: Didnt we already establish that this is not your car? im building one just like it. the pic has the same body as the one i will build. i have nothing to do so im posting my specs of my car and pics of what it may look like. i even may buy the car in the pic if the guy will sell it. i know where it was built and ive talked to the builder
Crazy 8s Drums Posted May 1, 2018 Report Posted May 1, 2018 I want a Billion dollars. Wait..make that a Trillion dollars! Orion XTR amplifiers Skar subs
Red-navi-916 Posted May 1, 2018 Report Posted May 1, 2018 I don’t get it. You want a fully built racecar and then add 2 18s in it? assuming you’re still under the age of 18 and just dreaming. Either way you do what you want. BUILDLOG http://www.stevemeadedesigns.com/board/ind...showtopic=61862 "98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!! Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
n8ball2013 Posted May 1, 2018 Report Posted May 1, 2018 Martin that you? Martin Luther? Martin Luther King? This is one dream that’s gonna cost more than change. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
