Need a new DSP on the market
i have a shop working in a year, or less. I'm making a business plan that will let me work out the bugs and have my workers have fun and build cars
yes ill have what ill sell. plus custom parts, every kind of CNC machine you can think of. we will do auto body as well.
my turbo kits for the BMW E46 M3 stage 5 has 1200rwhp and 1000fttq and you can add nitrous with 4 stage dpi wet spray.
and head and block no stages. just options of parts you would like in your engine with help by 36customz staff if needed
Bmw e46 m3 turbo coupe
This is a list of parts I would like to have on the E46
And I want black interior and black car blue accents.
I want AN fittings on everything under the hood even coolant hoses with AN fitting.
Engine
Debore sleeves
CP Alum con-rods
CP pistons 10.0:1 cr
Oversize wrist pins
3.5L Stroker crank
Custom FIC low Z fuel injectors
VAC Custom made top mount turbo manifold
PTE PT7675 CEA ported H cover Turbocharger ball bearing center
½” head studs if you can
VANOS Elimination Kit
Schrick cams highest DRA.
Stage 3 porting head
Super tech SS and inconel valves 1mm oversize
Super tech Dual valves springs and all super tech valve train
Pro EFI pro128 EMS
Pro EFI Display
Okada ign coils
M&W Pro Drag 6 6ch CDI
Bore throttle bodies and tapped for 4 stage NX nitrous
2 Electric cooling fans and alum rad
VAC custom 4” inlet intake manifold
Custom 3” inlet 4” outlet intercooler
Custom 4” down pipe, vibrant cat, 2 4” vibrant racing mufflers to 4 tips
Tial waste gates
Tial blow off valves
Body
Asuka body kit, hood and trunk lid
Sups Wheels and Brakes
Blue K Sport 8 pod cails front and rear big brakes kits
19”x 13” rear, 19”x 10” front VIP Moduler VR06 chrome rims Nitto tires
JRZ coilovers
Tubular subframes front and rear with unibody weld ins.
Tubular control and trailing arms front rear
Custom front spindles custom rear knuckles
Tilton 4 disk Clutch
 samsonas sin 6speed
Revshift flex disc
Chromalloy custom driveshaft and CVs
OS diff and 4.10:1 gears
fuel
Radium surge tank in fuel cell with methanol pumps. flexfuel CELL: 22 gal
4 Walbro F90000274 E85 pumps
-10 fuel feed lines
Radium fuel rail
NITROUS
4 Cold Fusion 20 pound bottles
12 NX double stage SX2 Nozzles
4 NX PRO POWER LIGHTNING ALCOHOL SOLENOID WITH .310 ORIFICE
4 NX Lightning 375
NX purge to the NX cooler on the intercooler
Nitrous fuel rails for cleaner install
Audio
Car pc with 7” screen and 10” screen
Alpine DSP PXA-H800 and RUX-C800
2 Sets Morel Audio ELATE TI 903
1 Set ELATE TI 503
2 Rockford Power T600-2
1 Rockford Power T400-2
1 Ground Zero GZCA 35K-SPL
2 Ground Zero Plutonium GZPW 18SPL-EXTREME
4 xs power XS30K batteries
windows tinted
Corbeau CR1 heated seats L20901: Black Leather
BMW RACING steering wheel
Dual HID Blue lens projector full color Halo Full Black housing head lights
LED black housing front side markers
LED tail lights
XK lighting under and inner
I would like to cut the rear seats out and back deck with custom roll cage combatable for my wheel chair
so I can fit two 18” subs and 4 batteries and 3 amps in the e46
5 minutes ago, robsimon799 said:
why do you want to smoke a joint?
Nah, bro, my meth dealer would be super pissed if he found out i cheated on his drugs with other drugs.
A 35K per coil huh? Ok
IG @walledsonic
